Geoprocessing arcobjects Intersect
3169
11-01-2015 11:02 PM
NigelDsouza
I have no idea as to how do I pass multiple input features to the intersect tool.
Here is my code
regards,
Nigel
Geoprocessor pGp = new Geoprocessor();
  IFeatureClass pGDMFclass = pGDMFLayer.FeatureClass;
 IFeatureClass pZoneFclass = pZoneFLayer.FeatureClass;
               Intersect pIntersect = new Intersect();
                    //Pass more than one feature
              pIntersect.in_features = pZoneFclass;
                pIntersect.join_attributes = "ALL";
                pIntersect.output_type = "INPUT";
                IWorkspace pWs = pFWS as IWorkspace;
                string path = pWs.PathName + "\\" + "TEST";
                pIntersect.out_feature_class = path;
                pGp.OverwriteOutput = true;
                pGp.Execute(pIntersect, null);
FreddieGibson
Honored Contributor
You can either put your feature classes into an array or pass a semi-colon delimited string into the parameter.
Update..did a quick search in the documentation and came across this page.
How to use multiple inputs
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#/How_to_use_multiple_in...
FreddieGibson
Honored Contributor
NigelDsouza
I have tried passing in an array but it still throws an exception. Could you write down the syntax please? I am doing the following. IFeatureClass [] inputfeturesArr = new IFeatureClass [2] inputfeturesArrp[0] = FClass1; inputfeturesArr[1] = FClass2; Regards, Nigel
