Geometric Network DataExtraction
832
02-15-2011 10:30 AM
PaulBlessing
I have a geometric network with several feature classes and I'd like to perform a DataExtraction to extract only a subset of the feature classes, and more importantly a subset of the features in each feature class.  I can see why IReplicaDescription::setTableExcluded wouldn't work, since the geometric network would need to keep all its feature classes.
However, it also doesn't seem to respect the definition queries I set using IReplicaFilterDescriptionEdit::setTableUsesDefQuery and IReplicaFilterDescriptionEdit::setTableDefQuery.
Is this by design, or is this a bug?  Code snippet below.
IWorkspace source = factory.openFromFile(srcPath, 0);
IFeatureWorkspace sourceF = new IFeatureWorkspaceProxy(source);
IWorkspaceName dest = factory.create(dir, "extracted", null, 0);
NamesEnumerator nameEnum = new NamesEnumerator();
nameEnum.add(sourceF.openFeatureDataset("MyDataset").getFullName());
ReplicaDescription replica = new ReplicaDescription();
replica.init(nameEnum, dest, false, esriDataExtractionType.esriDataExtraction);
replica.setReplicaModelType(esriReplicaModelType.esriModelTypeFullGeodatabase);
String defQuery = "Flag = 1";
for (int i = 0, count = replica.getTableNameCount(); i < count; i++) {
    IName tableIName = replica.getTableName(i);
    String tableName = new IDatasetProxy(tableIName.open()).getName();
    if ("Vertex1".equals(tableName)) {
        replica.setTableExcluded(i, true);
    } else if ("Vertex2".equals(tableName)) {
        replica.setTableExcluded(i, false);
        replica.setRowsType(i, esriRowsType.esriRowsTypeFilter);
        replica.setTableUsesDefQuery(i, true);
        replica.setTableDefQuery(i, defQuery);
    } else if ("Vertex3".equals(tableName)) {
    } else if ("Line1".equals(tableName)) {
    } else if ("Line2".equals(tableName)) {
DataExtraction extraction = new DataExtraction();
extraction.extract(replica, true);
PascalCoulon
Did you ever find a solution to the issue you have noticed where query definition are being ignored?
I have have the same issue, and I also noticed that related object are always downloaded despite set to false the parameters. See codes below.
public Boolean createReplica(LayerDefinition[] layerDefinitions, String TaskID)
            try
                //Define the output workspace
                setOuPutWorkspaceName();
                //Define the source workspace
                setinPutWorkspaceName();
                //Set the source replicate dataset
                IReplicaDescription2 rDDescription = initialiseReplica(layerDefinitions, m_sourceWorkspaceName, m_outPutWorkspaceName);
                if (rDDescription == null)
                    throw new GISException("replica not initialised");
                //If replica already exists unregister it!
                Workspace masterWorkspace = (Workspace)WorkspaceHelper.openFromSDEConnection(ApplicationConfigReader.Instance().GetValue("SDEFilePath"));
                IWorkspaceReplicas replicaWorkspace = (IWorkspaceReplicas)masterWorkspace;
                IReplica replica = replicaWorkspace.get_ReplicaByName("mycheckout_" + TaskID);
                if (replica != null)
                    IWorkspaceReplicasAdmin2 replicaWorkspaceManager = (IWorkspaceReplicasAdmin2)masterWorkspace;
                    replicaWorkspaceManager.UnregisterReplica(replica, true);
                ICheckOut _checkOut = new CheckOutClass();
                //Set to NOT Replicate related features
                _checkOut.CheckOutData(rDDescription, false, "mycheckout_" + TaskID);
            // Note that rDDescription.FetchRelatedObjects is equal to False.
  // However data replicated in the FGDB includes related features!
            catch (Exception e)
                throw new GISException(GISExceptionCode.ERROR_FGDB_NOT_INIT, e);
            return true;
private IReplicaDescription2 initialiseReplica(LayerDefinition[] layerDefinitions,
            IWorkspaceName sourceWorkSpaceName, IWorkspaceName OutputWorspaceName)
            // Create an enumerator for source datasets.
            IEnumName sourceEnumName = new NamesEnumeratorClass();
            IEnumNameEdit sourceEnumNameEdit = (IEnumNameEdit)sourceEnumName;
            for (int i = 0; i < layerDefinitions.Length; i++)
                // Create a name object for the source feature class.
                IFeatureClassName featureClassName = new FeatureClassNameClass();
                // Set the featureClassName properties.
                IDatasetName sourceDatasetName = (IDatasetName)featureClassName;
                sourceDatasetName.WorkspaceName = sourceWorkSpaceName;
                sourceDatasetName.Name = layerDefinitions.layerName;
                IName sourceName = (IName)sourceDatasetName;
                sourceName.NameString = layerDefinitions.layerName;
                // Add the name object for the source class to the enumerator.
                sourceEnumNameEdit.Add(sourceName);
            //Set the data extraction details
            IReplicaDescription2 rDDescription = new ReplicaDescriptionClass();
            rDDescription.Init(sourceEnumName, OutputWorspaceName, true, esriDataExtractionType.esriDataCheckOut);
            //rDDescription.AddDatasetNames(sourceEnumName);
            rDDescription.ReplicaModelType = esriReplicaModelType.esriModelTypeFullGeodatabase;
            IReplicaFilterDescriptionEdit rDDescriptionFilter = (IReplicaFilterDescriptionEdit)rDDescription;
            IReplicaFilterDescription dd = (IReplicaFilterDescription)rDDescription;
                for (int j = 0; j < rDDescription.TableNameCount; j++)
                    IName tableName = rDDescription.get_TableName(j);
                    if (tableName.NameString == layerDefinitions.layerName)
                          // The Query definition does not seem to be
//set as in the replica I get all features available in the table.
     rDDescriptionFilter.set_TableDefQuery(j, layerDefinitions.queryDefinition);
                        //rDDescriptionFilter.set_TableUsesQueryGeometry(j, true);
                        String query = dd.get_TableDefQuery(j);
            return rDDescription;
