Geodatabase Table to Local DBF file
1499
03-18-2011 01:55 PM
JoeMadrigal
I was wondering if anybody has any examples or tips that convert a table located in a geodatabase to a local dbf file.  I am switching my project from ArcGIS Desktop to ArcGIS Engine and I was using ExportTable method of IExportOperation to do this, but this object is not supported in ArcGIS Engine.  I was looking at IFeatureDataConverter or IGeoDBDataTransfer, but can't seem to figure if these will work for this.
Any help would be appreciated,
Joe
VivekPrasad
Joe
Try the below sample code
Try
            Dim pAoIni As IAoInitialize = New AoInitialize()
            pAoIni.Initialize(esriLicenseProductCode.esriLicenseProductCodeEngine)
            Dim pGeoProc As ESRI.ArcGIS.Geoprocessor.Geoprocessor = New ESRI.ArcGIS.Geoprocessor.Geoprocessor()
            Dim TableToDBF As ESRI.ArcGIS.ConversionTools.TableToDBASE = New TableToDBASE()
            TableToDBF.Input_Table = "D:\MajetiP\\PGDB.mdb\Table1"
            TableToDBF.Output_Folder = "D:\MajetiP\New Folder"
            pGeoProc.Execute(TableToDBF, Nothing)
        Catch ex As Exception
            MessageBox.Show(ex.Message.ToString())
        End Try
I tested it. It worked fine.
JoeMadrigal
Wow, that was too easy.  I tried it and it works great.   I'll have to use the geoprocessor more often.
Thank you!
VivekPrasad
Great..
Thank you!!
