Generate Near Table Parameters
618
05-28-2013 09:34 AM
JasonLaura
I am using VB.NET and the assembly access method to generate a near table as a component of a larger tool.
When I pass both the near_table and near_features parameter the same FeatureLayer the tool fails with error 99999.  If run the tool via ArcMap or hardcode the near_features parameter with the full path the tool runs flawlessly.
Is it necessary to open the featurelayer twice?  Via a new workspace?
(New ArcObjects programmer here...)
 Private Sub generateNearTable(ByVal distlayer, ByVal knn, ByVal DistanceTableOut)
        'Setup the geoprocessor
        Dim gp As New ESRI.ArcGIS.Geoprocessor.Geoprocessor
        Dim FeatureLayer = GetFLayerByName(distlayer)
        Dim NearFeatureLayer = GetFLayerByName(distlayer)
        'Setup Params
        Dim lcount As Long = knn
        'Get the generate near table tool
        Dim genneartable As GenerateNearTable = New GenerateNearTable()
        'Setup the Gp Environment
        Dim addtomap As Boolean = gp.AddOutputsToMap
        gp.TemporaryMapLayers = False
        gp.AddOutputsToMap = True 'Add the derived table to the map doc.
        gp.OverwriteOutput = True
        'Set Params
        genneartable.in_features = FeatureLayer
        genneartable.near_features = "C:\Users\jlaura\Desktop\TestData\Test_Points.shp"
        genneartable.out_table = DistanceTableOut
        genneartable.closest = False
        genneartable.closest_count = lcount 'This should be a parameter
        'Execute
        Try
            gp.Execute(genneartable, Nothing)
        Catch ex As Exception
        End Try
    End Sub
