Fitting circle/rectangle into a polygon
1221
07-22-2010 01:14 AM
spiskulaspiskula
Hi
I am writing a tool that would analyze usability of a parcel (represented by a polygon) by inscribing a geometry of given type into the parcell's shape. The types to inscribe are circle with given by user radius or a rectangle (width and height are  defined by user). Is there any build in support in esri for this kind of matching / fitting? Does anyone have any idea how to approach such task?
regards,
Szymon
FelixStracke
Hi
regards,
Szymon
Dear Szymon,
I am working on a same topic. I have to identify areas of a reectangular shape from 4km to 2km in irregular polygons. Currently I have not found a good solution. Did you found one?
Thanks and best regards
Felix
