Fire SelectionChanged event
1829
04-17-2011 10:34 PM
ChaesoonLim
Hi, All
I am using VB.NET of ArcEngine 9.3.
Question is how I can fire OnSelectionChanged event when selecting feature.
My code is like below.
       Dim featLayer As IFeatureLayer
       featLayer = CreateLayerAndAddtoMap(pFC)
        If featLayer Is Nothing Then Exit Sub
        Dim featSel As IFeatureSelection = CType(featLayer, IFeatureSelection)
        Dim qFilter As IQueryFilter = New QueryFilter
        qFilter.WhereClause = pFilterStr
        Dim activeView As IActiveView = axmapcontrol.ActiveView
        activeView.PartialRefresh(esriViewDrawPhase.esriViewGeoSelection,Nothing,activeView.Extent)
        featSel.Clear()
        featSel.SelectFeatures(qFilter, esriSelectionResultEnum.esriSelectionResultNew, True)
        featSel.SelectionChanged()
This code select feature well, but doesn't fire AxMapControl1.OnSelectionChanged event.
In debuging mode, after calling "featSel.SelectionChanged()", this doesn't go into the event sub routine.
I want to enable "Clear Selected Features Button" after selecting feature.
How can I fire SelectionChanged event?
Thanks in advance.
JohnHauck
I'll have to look at this some more but ISelectionEvents::SelectionChanged will fire the event properly. You could cast your IMap to ISelectionEvents and call SelectionChanged.
ChaesoonLim
Thanks, John.
I coded as you suggested. But unfortunately the result is same as before.
I attached my very simple code.
Would you test my code and check it.
The code is VB.NET 2008.
Test procedure is like this.
1. edit the line qFilter.WhereClause = "OBJECTID = 254" in Sub
btnSelectQuery_Click
2. start debugging.
3. click Add Data button and add your feature class.
4. start editing
5. click "SelectQuery" button that I added.
6. open attribute window
Can you see the attribute of the selected feature in the attribure window?
I couldn't see. And the featSel.SelectionChanged() code doesn't fire ISelectionEvents.SelectionChanged event.
Why? it's very strange. Is my code something wrong?
Please check the code and give me some suggestion.
Thanks a lot.
JohnHauck
I made the following changes:
    'Private WithEvents m_pSelectionEvents As Map
    Private m_pSelectionEvents As ISelectionEvents
In Form_Load:
        ' m_pSelectionEvents = DirectCast(m_mapControl.Map, Map)
        m_pSelectionEvents = CType(m_mapControl.Map, ISelectionEvents)
In btnSelectQuery_Click:
        'featSel.SelectionChanged()
        m_pSelectionEvents.SelectionChanged()
ChaesoonLim
Hi, John.
Thanks for your rapid reply.
For your kind help, everything is cleared.
I'm very happy~~
Thanks again.
