Hi everyone,
I am currently trying to find out how I could get the information, if a specific version of my versioned workspace has changes or not. The purpose is to provide the information to a user over all versions avaliable. Therefor, i cannot use IVersionEdit.ModifiedClasses, as If I understand, this will only return something after reconcile.
Is there a way to find out, if a version has local changes?
Lionel
I don't know ArcObjects, but can throw out some ideas from the user side of versioned editing to see if that rings a bell and correlates with an ArcObject process/method.
Chris Donohue, GISP
When looking through the documentation, this can be done with the IVersionedTable.Differences method. ( http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#72dfe883-e4d7-4925-835c-02bc513f91aa... )
Basically you iterate through each version you want to check for edits and set up IVersion objects for the child and parent version... for each versioned object in SDE (I only check tables and features in the example below), cast it to IVersionedTable and call Differences with the type of edits you are looking for. I call it 6 times. It will return a DifferenceCursor which you can use to iterate over to see the IRow objects with differences.
You have to verify you are working with a versioned dataset or you will receive an error when calling the Differences method, or you could call IsRegisteredAsVersioned from the IVersionedObject but I had very poor performance from this call.
The Differences method has 6 options for the table returned. See esriDifferenceType
I've been developing the code below but I'm only checking versions with Default as the parent, which works for our environment. I also check to see if the version has any potential conflicts without reconciling (esriDifferenceType 3 through 5). The results have been accurate so far but I put this together pretty quickly. This is part of a larger addin so you'll have to modify for your needs.
Good luck~
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.GeodatabaseModule FindVersionChanges
Private Sub writeLogLine(ByVal logLine As String)
Dim logFile As String = "C:\temp\test.csv"Dim file As System.IO.StreamWriter
file = My.Computer.FileSystem.OpenTextFileWriter(logFile, True)
file.WriteLine(logLine)
file.Close()End Sub
Friend Sub listVersionEdits()
writeLogLine("VersionName, VersionedObject, Inserts, Deletes, Updates, Conflict_Update_Update, Conflict_Update_Delete, Conflict_Delete_Update")
Dim connProp As IPropertySet = New PropertySetClass
With connProp
.SetProperty("DBCLIENT", "SQL")
.SetProperty("SERVER", String.Format("{0}\{1}", "<your sql server>", "<sql instance>"))
.SetProperty("INSTANCE", String.Format("sde:sqlserver:{0}", .GetProperty("SERVER")))
.SetProperty("DATABASE", "PODS")
.SetProperty("AUTHENTICATION_MODE", "OSA")
.SetProperty("VERSION", "sde.DEFAULT")
End WithDim sdeFactoryWkspType As Type = Type.GetTypeFromProgID("esriDataSourcesGDB.SdeWorkspaceFactory")
Dim sdeFactoryWksp As IWorkspaceFactory = CType(Activator.CreateInstance(sdeFactoryWkspType), IWorkspaceFactory)
Dim sdeWksp As IWorkspace = sdeFactoryWksp.Open(connProp, 0)
Dim clVersionWksp As IVersionedWorkspace4 = CType(sdeWksp, IVersionedWorkspace4)Dim defaultVersion As IVersion = clVersionWksp.FindVersion("sde.DEFAULT")
Dim versionedDatasets As New List(Of String)
''get list of versioned data
Dim enumDatasets As IEnumDataset = sdeWksp.Datasets(esriDatasetType.esriDTAny)
Dim curDataset As IDataset = enumDatasets.Next()
While curDataset IsNot NothingIf curDataset.Type = esriDatasetType.esriDTFeatureClass Or curDataset.Type = esriDatasetType.esriDTTable Then
Try
Dim versionedObj As IVersionedObject3 = CType(curDataset, IVersionedObject3)
''If versionedObj.IsRegisteredAsVersioned Then versionedDatasets.Add(curDataset.Name)
versionedObj = Nothing
Catch ex As ExceptionEnd Try
ElseIf curDataset.Type = esriDatasetType.esriDTFeatureDataset Then
Dim enumFeatDataset As IEnumDataset = curDataset.Subsets()
Dim subDataset As IDataset = enumFeatDataset.Next()
While subDataset IsNot Nothing
Try
If subDataset.Type = esriDatasetType.esriDTFeatureClass Then
Dim versionedObj As IVersionedObject3 = CType(subDataset, IVersionedObject3)
End If
subDataset = enumFeatDataset.Next()
End While
If subDataset IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(subDataset)
If enumFeatDataset IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(enumFeatDataset)End If
curDataset = enumDatasets.Next()
End WhileIf curDataset IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(curDataset)
If enumDatasets IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(enumDatasets)
'sort versioned objects
versionedDatasets.Sort()
Dim allVersions As IEnumVersionInfo = clVersionWksp.Versions
Dim curVersion As IVersionInfo = allVersions.Next()
While curVersion IsNot Nothing
If curVersion.Parent.VersionName = "sde.DEFAULT" ThenDim curVersionVersion As IVersion = clVersionWksp.FindVersion(curVersion.VersionName)
For Each vDataset As String In versionedDatasets
Dim defaultFWS As IFeatureWorkspace = CType(defaultVersion, IFeatureWorkspace)
Dim curVersionFWS As IFeatureWorkspace = CType(curVersionVersion, IFeatureWorkspace)Dim defaultTable As ITable = defaultFWS.OpenTable(vDataset)
Dim curVerTable As ITable = curVersionFWS.OpenTable(vDataset)
'Create a difference cursor.
Dim versionedTable As IVersionedTable = CType(curVerTable, IVersionedTable)Dim editCountInVersion As New Dictionary(Of String, Integer) From {{"INSERT", 0}, {"UPDATE", 0}, {"DELETE", 0}} ''update type : count
Dim conflictCount As New Dictionary(Of String, Integer) From {{"UPD_UPD", 0}, {"UPD_DEL", 0}, {"DEL_UPD", 0}} ''CurVersion_DefaultVersion
For x = 0 To 5Try
Dim differenceCursor As IDifferenceCursor = versionedTable.Differences(defaultTable, x, Nothing)Dim oid As Integer = -99
Dim differenceRow As IRow = Nothing
differenceCursor.Next(oid, differenceRow)
While oid <> -1
Select Case x
Case 0
editCountInVersion("INSERT") += 1
Case 1
editCountInVersion("DELETE") += 1
Case 2
editCountInVersion("UPDATE") += 1
Case 3
conflictCount("UPD_UPD") += 1
Case 4
conflictCount("UPD_DEL") += 1
Case 5
conflictCount("DEL_UPD") += 1
End SelectdifferenceCursor.Next(oid, differenceRow)
End WhiledifferenceRow = Nothing
differenceCursor = Nothing
'Debug.Print(String.Format("{0}, Error: {1}", vDataset, ex.Message))
End Try
NextDim logStr As String = String.Format("{0}, {1}, {2}, {3}, {4}, {5}, {6}, {7}", curVersion.VersionName, vDataset,
editCountInVersion("INSERT"), editCountInVersion("DELETE"), editCountInVersion("UPDATE"),
conflictCount("UPD_UPD"), conflictCount("UPD_DEL"), conflictCount("DEL_UPD"))Debug.Print(logStr)
writeLogLine(logStr)versionedTable = Nothing
curVerTable = Nothing
defaultTable = Nothing
curVersionFWS = Nothing
defaultFWS = NothingNext
curVersionVersion = Nothing
Else
Debug.Print(String.Format("{0}, Version not child of Default... skipping", curVersion.VersionName))
End If
curVersion = allVersions.Next()
End WhileEnd Sub
End Module
