FeatureClass extent vs domain question
1972
07-21-2010 12:51 PM
DeannaDelapasse
I'm using ArcObjects (Java) to create feature classes for my ARCGis 9.3.  In ArcCatalog I can see that my feature classes have Domain values set, but in ArcMap on the layer properties the extent values are blank.
Can you tell me what the difference is in those two?  And how I can set the extent?
My Layers won't "zoom to layer" and I'm guessing that is why.  My shapefiles work fine.  I can zoom to the specific selected row (so I think my spatialRef was set ok), but not to the layer.    I have tried in datasets and standalone - same result.
AlexanderGray
Honored Contributor
It is likely that the layer's areaOfInterest is empty.  This happens if the featureclass is empty but it could happen other ways too.  Typically, zoom to layer zooms to the extent of the data.  I know there are some times problems where the AOI no longer reflects the extent of the data if a bunch of features are deleted.  ILayer2 has read/write on it.  Shapefiles get their AOI differently so it is possible they work fine without setting it.
http://forums.esri.com/Thread.asp?c=93&f=992&t=67243
DeannaDelapasse
This is driving me crazy!  I did finally figure out that it only happens when I use a FeatureCursor/FeatureBuffer.  When I use direct inserts my extent shows up in the Layer source tab.
How can I get a reference to my layer (I only create a FeatureClass inside a FeatureDataset - I guess a default layer is being created for me?)?
Sorry if that's a really dumb question.  I am not very comfortable with ArcObjects yet.
KirkKuykendall
This sounds like a bug.  As a workaround, I'd try IFeatureclassManage.UpdateExtent.
