Feature Selection Using custom button
2333
08-31-2011 01:15 PM
MichaelMurphy8
I'm trying to build a tool to select a feature on the map.  I want to be able to toggle on/off the selection using a button on a DockableWindow.  What's the best way to go about this?  I don't see an easy way to add ArcGIS tools to a DockableWindow in the form designer for the DockableWindow.
Thanks
MichaelMurphy8
OK.  So to accomplish this, you have to build and use an ESRI Custom Tool.  Here's what I did...
On the DockableWindow button's On_Click method, i reference a Custom ESRI Tool that I created.
private void button1_Click(object sender, EventArgs e) {
            IApplication app = Hook as IApplication;
            UseCustomToolOnWindowsForm(app, @"Dharma_Inst_CustomUIElements_FindFeaturesFromPoint");
<<Insert the following ESRI Snippet>>
public void UseCustomToolOnWindowsForm(IApplication application, System.String uidValue){...}
