feature selection: Attribute query
1252
05-22-2011 09:23 PM
shivagugila
Greeting,
I am trying to select features using attribute query. Variable are referenced to listbox. Can anyone please let me why my whereclause is set to false and i am unable to select the features.
please ref the attached screenshot.
pqf.WhereClause = fieldname = fieldvalue     :    is the expression i used to implement fieldname and fieldvalue as variables.Tried various options like using &, ", ( etc etc...but did not find a way to use both as variables(fieldname and fieldvalue).
thanks n regards,
shiva
NeilClemmons
Honored Contributor
The WhereClause property expects a string, therefore you must set it using a string expression.
queryFilter.WhereClause = fieldName & " = '" & stringValue & "'"
If the field isn't a text field then you must remove the single quotes.
shivagugila
Thanks Neil,
That single quote made the difference....( i missed that in my line of code)
thanks for the info.
have a nice day..
regards,
shiva
