Export comma delimited text file to dbf in VB dotnet
1571
10-16-2013 04:06 PM
scottvalentine
Can a comma delimited text file be exported to a dbf file using IExportOperation.ExportTable Method? If so could someone point me to some sample code for the export?
HailiangShen
Here is what i usually write .dbf file (corresponding to interface ITable)
1 create table in folder or geodatabase, refer to http://help.arcgis.com/en/sdk/10.0/arcobjects_net/componenthelp/index.html#//0049000000r4000000
2 write data into the table with ICursor, the operation is exactly the same as writing into featureclass if you are familiar with that operation except you do not need to write geometry for table
E.g. the following code will insert rows (from your csv file) into table
Dim cur as ICursor = tbl.Insert(true)
Dim buff as IRowBuffer
' loop your csv rows data
    buff = tbl.CreateRowBuffer()
    buff.Value(index) = ...
    cur.InsertRow(buff)
cur.Flush()
DuncanHornby
MVP Notable Contributor
An alternate approach is to call the existing Table to Table conversion tool using the geo-processor. If you have never called existing tools before then have a look at this page.
Duncan
