EsriRegasm.exe error
3294
01-01-2012 07:24 PM
surender_reddykonatham
sir im using vs2010 with arcgis10. im creating one command while  build the code getting below error.pls find the solution sir.
Error 1 The command "esriRegasm.exe "C:\Users\suren123\documents\visual studio 2010\Projects\ArcMapClassLibrary1\ArcMapClassLibrary1\bin\Debug\ArcMapClassLibrary1.dll" /p:Desktop /s" exited with code -1.
RichardWatson
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//0001000004n6000000
Try running it with the error console switch from a command window which is running as an administrator.  What is the output?
