ESRI Map control freezes or crushes
617
04-22-2012 04:28 AM
MaorHayun
I have a MapControl version 10 that sometimes on load layers or just refreshing the map,it stuck on finalizer thread probably tring to release an instance of an STA COM component, and it is stuck waiting for the STA thread to become available. second scenario is my application just crushed an i get unhandled exception of access violation.
I see that the main STA thread is probably stuck and prevents from other threads to execute right.
Have any of you encountered this type of problem?
look at the dump analysis below. (I did not put access violation exception), It looks like all the other thread waiting to the STA.
Thanks Uri.
Thread 16 - System ID 3476
Entry point   0x00000000
Create time   4/2/2012 1:45:18 PM
Time spent in user mode   0 Days 00:00:00.00
Time spent in kernel mode   0 Days 00:00:00.00
Function   Source
ntdll!NtWaitForSingleObject+15
KERNELBASE!WaitForSingleObjectEx+98
kernel32!WaitForSingleObjectExImplementation+75
kernel32!WaitForSingleObject+12
BasemapLayer+5100e
BasemapLayer+4fa4b
msvcr90!_callthreadstartex+1b   f:\dd\vctools\crt_bld\self_x86\crt\src\threadex.c @ 348 + 6
msvcr90!_threadstartex+69   f:\dd\vctools\crt_bld\self_x86\crt\src\threadex.c @ 326 + 5
kernel32!BaseThreadInitThunk+e
ntdll!__RtlUserThreadStart+70
ntdll!_RtlUserThreadStart+1b
Thread 2 - System ID 5188
Create time   4/2/2012 1:45:11 PM
Time spent in user mode   0 Days 00:00:01.326
Time spent in kernel mode   0 Days 00:00:00.109
This thread is making a COM call to thread 9 within the same process
Full Call Stack
Function   Source
ole32!GetToSTA+ad    ole32!CRpcChannelBuffer::SwitchAptAndDispatchCall+140
ole32!CRpcChannelBuffer::SendReceive2+ef
ole32!CAptRpcChnl::SendReceive+af
ole32!CCtxComChnl::SendReceive+1c5
ole32!NdrExtpProxySendReceive+49
rpcrt4!NdrpProxySendReceive+e
rpcrt4!NdrClientCall2+1a6
ole32!ObjectStublessClient+a2
ole32!ObjectStubless+f
ole32!RemoteReleaseRifRefHelper+a5
ole32!RemoteReleaseRifRef+b0
ole32!CStdMarshal::DisconnectCliIPIDs+2ec
ole32!CStdMarshal::Disconnect+1ba
ole32!CStdIdentity::~CStdIdentity+8c
ole32!CStdIdentity::`vector deleting destructor'+d
ole32!CStdIdentity::CInternalUnk::Release+6e
ole32!IUnknown_Release_Proxy+11
clr!ReleaseTransitionHelper+e
clr!SafeReleaseHelper+87
clr!SafeRelease+2f
clr!RCW::ReleaseAllInterfaces+4b
clr!RCW::ReleaseAllInterfacesCallBack+c4
clr!RCW::Cleanup+22
clr!RCWCleanupList::ReleaseRCWListRaw+18
clr!RCWCleanupList::ReleaseRCWListInCorrectCtx+10a
clr!RCWCleanupList::CleanupAllWrappers+83
clr!SyncBlockCache::CleanupSyncBlocks+de
clr!Thread::DoExtraWorkForFinalizer+3b
clr!WKS::GCHeap::FinalizerThreadWorker+9d
clr!Thread::DoExtraWorkForFinalizer+114
clr!Thread::ShouldChangeAbortToUnload+101
clr!Thread::ShouldChangeAbortToUnload+399
clr!ManagedThreadBase_NoADTransition+35
clr!ManagedThreadBase::FinalizerBase+f
clr!WKS::GCHeap::FinalizerThreadStart+10c
clr!Thread::intermediateThreadProc+4b
