ESRI.ArcGIS.AnalysisTools.MultipleRingBuffer
2739
6
02-12-2014 01:32 AM
JohnStallings
Ok... First off I am a first time user of forums EVER, so as you might imagine I have racked my brain to no end with not luck whatsoever. Also, I am not a very good programmer, just thought I should insert that in case some of you programming wizards are wondering why this code look so terrible.
Here is the setup;
I need for my user to be able to input multiple distances for a buffer (thus the Multiple Ring Buffer Tool)
I am using a text box a list box and a add button. Once the action button (Buffer) is activated the numbers in the list box are converted to a List(of Double).
Where my problem comes into play is the .Distances property. If my user enters 500 <list box row 0> and 1000 <list box row 1>
The buffer generates a single buffer with a distance of 500.1 instead of 2 entries per Feature i.e. 1 - 500, 2 - 1000.
I have tried what I think to be everything. Look at my code below; and I will explain more after the code.
<Code>
Public Sub MultipleRingBuffer(ByVal UBuffer As List(Of Double))
        Dim GP As Geoprocessor = New Geoprocessor()
        GP.OverwriteOutput = True
        Dim out As String = "RISK_BUFFER_" & FCName 'FCName is populated from an earlier process in the program.
        Dim look As String = """" & String.Join(",", UBuffer.ToArray) & """"
        '' Create the tool process object.
        Dim bufferTool As ESRI.ArcGIS.AnalysisTools.MultipleRingBuffer = New ESRI.ArcGIS.AnalysisTools.MultipleRingBuffer
        With bufferTool
            .Input_Features = Open.OpenFeatureClassFromString(path & name & ".gdb\" & FCName)
            .Output_Feature_class = path & name & ".gdb\" & out
            .Distances = look
            .Buffer_Unit = "Feet"
            .Field_Name = "INPUT_DISTANCES"
            .Dissolve_Option = "NONE"
        End With
        RunTool(GP, bufferTool, Nothing)
    End Sub
    Private Sub RunTool(ByVal geoprocessor As Geoprocessor, ByVal process As IGPProcess, ByVal TC As ITrackCancel)
        geoprocessor.OverwriteOutput = True
        Try
            geoprocessor.Execute(process, Nothing)
            'ReturnMessages(geoprocessor)
        Catch err As Exception
            'Console.WriteLine(err.Message)
            MessageBox.Show(err.Message)
        End Try
    End Sub
</Code>
look is the variable that I am using to push to the .Distances Property. Also Notice the UBuffer is being received from another part of the program.
What I have tried for the .Distances;
1. Passing UBuffer directly - .Distances = UBuffer (Did not Work)
2. Dim look As String = """" & String.Join(" ", UBuffer.ToArray) & """" Notice the <space>
3. Dim look As String = String.Join(",", UBuffer.ToArray)  Notice the Missing """" at the begin and end of the string
4. Dim look As String = """" & String.Join(";", UBuffer.ToArray) & """" Notice the ";"
5. Dim look as Object = UBuffer - multiple iterations of this
This can go on and on... I suspect I am either completely wrong by using the above look variable or I have something minor wrong.
Thank you!
JohnStallings
The answer was slapping me in the face the entire time.
I was using geoprocessor.Execute
Use geoprocessor.ExecuteAsync
KenBuja
MVP Esteemed Contributor
In my experience, the first thing to do when you run into issues coding a geoprocessing tool is to run it manually. When it runs successfully, take a look at the executing statement to see what the parameters should be. I ran the Multiple Ring Buffer and got this as the result
Messages
Executing: MultipleRingBuffer sample_test C:\Default.gdb\sample_test_MultipleRingBuff 500;1000 Meters distance NONE FULL
Start Time: Wed Feb 12 08:39:34 2014
Running script MultipleRingBuffer...
Completed script MultipleRingBuffer...
Succeeded at Wed Feb 12 08:39:51 2014 (Elapsed Time: 17.00 seconds)
In this case, the distances have to be separated by a semicolon.
JohnStallings
If you look at number 4 I had already tried that and I receive a Com Error. Which has me wondering if I am having some sort of conflict.
In the same Solution I have;
ESRI.ArcGIS.Geoprocessing
ESRI.ArcGIS.Geoprocessor
I looked at the error from the JIT so I could get a full picture and here it is, or at least part of it:
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM component.
at ESRI.ArcGIS.Geoprocessing.GeoProcessorClass.Execute(String Name, IVariantArray ipValues, ITrackCancel pTrackCancel)
at ESRI.ArcGIS.Geoprocessor.Geoprocessor.ExecuteInner(IGPProcess process, ITrackCancel trackCancel, IGeoProcessor igp, IVariantArray iva)
at ESRI.ArcGIS.Geoprocessor.Geoprocessor.Execute(IGPProcess process, ITrackCancel trackCancel)
I Suspect something is not being passed correctly, either through the Geoprocessor or the IGPProcess.
JohnStallings
By the way, thank you for taking the time to look into this error for me, now I know for sure it is the semicolon. Now I need to figure out what I suspect to be the real error.
Thank you again!
KenBuja
Have you verified that the variable "look" is what you expected it to be?
JohnStallings
Yes Sir.
I might ultimately have to contact ESRI directly, I am exploring every rabbit hole to no end. what I am looking into right now has me scratching my head a little.
If you look at the Desktop Help for Multiple Ring Buffer (it is a Python Example), however it shows multiple distances being passed into the Distances property.
However
if you look here (Path might be different for you)
C:\Program Files (x86)\ArcGIS\Desktop10.2\ArcToolbox\Scripts
<MultiRingBuffer.py>
Look at this it seems that each distance is ran separately then merged into a single FC at the end.
# Loop through each distance creating a new layer and then buffering the input.
        #  Set the step progressor if there are > 1 rings
        if len(distList) > 1:
            gp.SetProgressor("step", "", 0, len(distList))
            stepProg = True
        else:
            gp.SetProgressor("default")
            stepProg = False
        bufferedList = []
        # Buffer the input for each buffer distance.  If the fieldName is different than
        #  the default, add a new field and calculate the proper value
        for dist in distList:
            if stepProg:
                gp.SetProgressorPosition()
            gp.SetProgressorLabel(msgBuffRings + str(dist) + "...")
            bufDistance = "%s %s" % (dist, unit)
            bufOutput = gp.Buffer_analysis(input, gp.CreateUniqueName("buffer", scratchWks),
                                           bufDistance, sideType, "", dissolveOption).getOutput(0)
            if fieldName.lower() != "buff_dist":
                gp.AddField_management(bufOutput, fieldName, "double")
                gp.CalculateField_management(bufOutput, fieldName, dist, "PYTHON")
            bufferedList.append(bufOutput)
        gp.ResetProgressor()
        gp.SetProgressorLabel(msgMergeRings)
This is the current rabbit hole I am chasing.
JohnStallings
