Error instancing a FileGDBWorkkspaceFactotyClass
5066
10-07-2010 07:32 AM
PedroAbreu
With ArcGIS Desktop 10, Sometimes this line of code:
IWorkspaceFactory factory = new FileGDBWorkspaceFactoryClass();
throws this exception:
Unable to cast object of type System.__ComObject to type ESRI.ArcGIS.DataSourcesGDB.FileGDBWorkspaceFactoryClass
I'm puzzled... Anybody has experienced this yet?
NeilClemmons
Honored Contributor
If you're running this code in a standalone application then you need to check out a license prior to running any ArcObjects code.  You also shouldn't be using New to create an instance of the workspace factory.  A workspace factory is a singleton object and should be instantiated using the Activator class.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Interacting_with_single...
Vidar
Thank you Neil - you've helped me on and off for 20 years now!!
NattawutWiginiyatanee1
Yep! Thank you. this helped. But I still wonder most of my projects. this code won't break.
But for my current project it breaks. And Neil Clemmons answer solves the problem.
PedroAbreu
Neil,
I've been coding ArcObjects for so many years, and never had a problem with instancing Workspaces Factories with the "new" keyword.
But there's always a first for everything, and this was my first.
Thank you for your help 😉
