Enable/Disable IToolbarItem
981
05-28-2010 10:41 AM
GustavoFerrero
Hi All,
I've created a AxToolbarControl which contains some commands. I need to hide or disable some command on this toolbar. However, I was not able to find the way to do that.
Does anyone know how to do that (disable a tool bar item)?
Thanks in advance.
Gustavo.
GuillermoMarinez
Hi
each command class have a enable property , you can override this property like this:
Public Overrides ReadOnly Property Enabled() As Boolean
    Get
      Return enabed_or_not_enable_custom_function()
    End Get
  End Property
