Enable / disable a button when start / stop an editing session
972
09-12-2011 10:43 AM
ducksunlimited
HI All,
Hope I can get some help here.
I have an ArcGIS 10 add-in (IDE VB.NET Express 2008) with a button. I want this button to be enabled only when an editing session is started. Here is what I got. Also I added the onDemand = "Flase" property for the button. Any help would be appreciated.
Protected Overrides Sub OnUpdate()
        Dim application As ESRI.ArcGIS.Framework.IApplication = Nothing
        Dim pID As New UIDClass()
        pID.Value = "esriEditor.Editor"
        Dim pEditor As IEditor
        pEditor = application.FindExtensionByCLSID(pID)
        If pEditor.EditState = 1 Then
            Me.Enabled = True
        End If
    End Sub
Russel
by Anonymous User
Not applicable
In its simplest form the update stub will look like this:
'VB
    Enabled = (_editor.EditState = esriEditState.esriStateEditing)
  End Sub
This assumes you have set _editor in the constructor.
The onDemand tag should also be false as you have stated.
ducksunlimited
Worked - Thank you!
'VB
  End Sub
