draw circle with radius in meters on a map with geographic coordinate system
4615
10-19-2010 07:34 PM
DarkoRadiceski
Hi all,
I have been looking around but havent been able to find any good pointers on how i can create a circle if i know the center point and wanted radius in meters on an map in a geographic coordinate system.
I found this class that allows me to create a circular arc with a center point and radius:
Dim pConstCArc As IConstructCircularArc
pConstCArc.ConstructCircle(geometry, circleRadiusValue, True)
But is says that the radius value will take the units of the map. So if i put 1000 for meters that will be assumed to be 1000 degrees. Not quite the same.
If it was a projected coordinate system it would have been easy.
Any advice?
Thank you
Dan
DarkoRadiceski
After some searching i came accross the IUnitConverter
Did something like this:
        Dim myConverter As IUnitConverter = New UnitConverter()
        Dim datasetUnits As Double = myConverter.ConvertUnits(meters, esriUnits.esriMeters, esriUnits.esriDecimalDegrees)
Would this be the way to go or am i doing it all wrong?
GuyUrban
If you are still looking. I have VB code as well.
Draw a circle on arcmap using java
    static void drawCircle2(IActiveView activeView) throws Exception
    double Px;
    double Py;
    double Radius;
    IGraphicsContainer graphicsContainer = activeView.getGraphicsContainer();
    // set up the color
    IRgbColor rgbColor = new RgbColor();
    rgbColor.setRed(0);
    rgbColor.setGreen(255);
    rgbColor.setBlue(0);
    IColor color = rgbColor;
    // make the line and define its color, style and width
    ISimpleLineSymbol LineSymbol = new SimpleLineSymbol();
    LineSymbol.setColor(color);
    LineSymbol.setStyle(esriSimpleLineStyle.esriSLSSol id);
    LineSymbol.setWidth(2);
    ISymbol symbol = (ISymbol)LineSymbol;
    //create circle element
    ILineElement pCircleLineElement = new LineElement();
    pCircleLineElement.setSymbol(LineSymbol);
    IElement pCircleElement = (IElement)pCircleLineElement;
    // create point and radius
    Px = 0.0;
    Py = 0.0;
    Radius = 10.0;
    // Create circle geometry
    IPoint centerPoint = new Point();
    centerPoint.putCoords(Px,Py);
    IConstructCircularArc pCircularArc = new CircularArc();
    pCircularArc.constructCircle(centerPoint,Radius,tr ue);
    ISegment Seg = (ISegment)pCircularArc;
    ISegmentCollection SegCollection = new Polyline();
    SegCollection.addSegment(Seg,null,null);
    pCircleElement.setGeometry((IGeometry)SegCollection);
    //add the element to the map and draw it.
    graphicsContainer.addElement(pCircleElement,0);
    activeView.partialRefresh(esriViewDrawPhase.esriVi ewGraphics,null,null);
HaroonMia
Hi
I am interested in the VB code. How can I get this from you? My email address is [email protected]
Gratefully
Haroon
    double Px;
    double Py;
    double Radius;
    // set up the color
    rgbColor.setRed(0);
    Px = 0.0;
    Py = 0.0;
    Radius = 10.0;
