Dockable Window Template does not seem to work - Where is it.
1266
01-16-2014 04:49 AM
RickeyTom
I am using the new ArchMap .NET SDK (SDK_DotNet) that came with version 10.2.1 and VS 2012.
I create a project using ArcGIS/Desktop Add-ins/ArcMap Add-in
  Fill in the values on the welcome.
  For Add-In components, I (only) select Dockable Window.
  Click Finish and run.
I see the add-in is added to ArcMap but the dockable window does not appear anywhere.
It is not clear what I need to do to get it to display at this point. From what I gather from the documentation,
the wizard is supposed to automate this.
I can add buttons and they are visible in the customize (Mode) /Commands so I know the add-in works.
The following link describes creating a project with dockable windows in an older version of ESRI (10.0)
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//00010000014w000000
But the wizard has changed for 10.2.1
If I create an empty project and then attempt to insert the add-in after, the project does not even compile.
I did get the simple logger console dockable window project to work, but I believe it is using the old style 10.0 pattern.
What am I doing wrong.
NOTE: I noticed that the created project targeted .NET 4.5. But I tried in in 3.5 and 4.0 and the results where the same.
Where is that dockable window.
I uploaded the project that the wizard generates.
ConorBarber1
With IDockableWindow, there are two components: The windows form component, and the ESRI IDockableWindow object inside which the windows form is embedded.
First, you need to get an instantiation of your ESRI IDockableWindow:
public IDockableWindow get_Window(out IDockableWindow dockWindow)
            UID dockWinID = new UIDClass();
            dockWinID.Value = ThisAddIn.IDs.DockableWindow1;
            dockWindow = ArcMap.DockableWindowManager.GetDockableWindow(dockWinID);
            dockWindow.Caption = "Dockable Window Caption Here";
            return dockWindow;
Now let's say you want to show your dockable window when a button is clicked. Declare your dockable window and call the IDockableWindow.Show() method in your button OnClick event:
        public ShowDockableWindowButton()
        protected override void OnClick()
            IDockableWindow dockWindow = get_Window(out dockWindow);
            dockWindow.Show(true);
