Displaying field names of a Feature Class
1555
11-09-2022 11:33 PM
ShanmugapriyaL1
I am new to this Arc Objects SDK platform.
I can able to get the feature class names from Geodatabase.
I want to display the field names of a feature class which is from Geodatabase.
Kindly anyone help me out in this. It will be more helpful if anyone has solution for this.
BrentHoskisson
The IFeatureClass object has a Fields property which is a collection of all the fields.
You will need to iterate through each IField object in the IFields property.  Get the count from the IFields and set a for loop.  Get each IField object for each index and there is a Name object.
//fc is your featureclass object...
for(int i = 0; i < fc.Fields.FieldCount; i ++)
IField f = fc.Fields.get_Field(i);
string name = f.Name;   //collect these...
Brent
BrentHoskisson
Brent
ShanmugapriyaL1
Thank you for your reply
