Define Projection using VB.NET in ArcCatalog
1036
01-18-2011 05:12 AM
RuchiraWelikala
Hi all,
I'm trying to automate a process that I constantly do manually in ArcCatalog.  I export shapefiles from CAD and define their projection to NAD83 Zone 17 using ArcCatalog.
I want to press a command button in ArcCatalog (in the toolbar) and have the selected shapefile be defined to NAD 83 Zone 17.
Here's the code I have so far, but I can't seem to find away to cast the IGxObject to a feature layer to define it's projection..would I even have to cast it?
Private Sub ProjectShapefile()
        Try
            Dim pGApp As IGxApplication = m_application
            Dim pGxObj As IGxObject = pGApp.SelectedObject
            Dim pGxDataset As IGxDataset
            If (TypeOf (pGxObj) Is GxShapefileDataset) = False Then
                'If pGxObj.Category <> "Shapefile" Then
                MsgBox("Make a valid Selection")
                Exit Sub
                'End If
            End If
            Dim pSpatRefFact As ISpatialReferenceFactory
            Dim pPCS As IProjectedCoordinateSystem
            Dim pSpatialRef As ISpatialReference
            pSpatRefFact = New SpatialReferenceEnvironment
            pPCS = pSpatRefFact.CreateProjectedCoordinateSystem(esriSRProjCSType.esriSRProjCS_NAD1983UTM_17N)
            Dim gxShape As GxShapefileDataset = New GxShapefileDataset
            gxShape = pGxObj
            pGxDataset = pGxObj
            Dim pGeoDataset As IGeoDataset = pGxDataset
            Dim pGeoDatasetEdit As IGeoDatasetSchemaEdit = gxShape
            If pGeoDatasetEdit.CanAlterSpatialReference = True Then
                ' Alter the target layer's spatial reference
                pGeoDatasetEdit.AlterSpatialReference(pPCS)
            Else
                Exit Sub
            End If
            ' Get the spatial reference information and export it to a prj file
            pSpatialRef = pGeoDataset.SpatialReference
            pGApp.Refresh(pGxObj.Parent.FullName)
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
RuchiraWelikala
I got it to work using the following code:
    Private Sub ProjShapefile()
        Dim pGxApp As IGxApplication = m_application
        Dim pGxObj As IGxObject = pGxApp.SelectedObject
            Exit Sub
        End If
        Dim pGxDataset As IGxDataset = pGxObj
        Dim pDataset As IDataset = pGxDataset.Dataset
        Dim pGeoDataset As IGeoDataset = pDataset
        Dim pGeoDatasetEdit As IGeoDatasetSchemaEdit = pGeoDataset
        Else
            MsgBox("error")
            Exit Sub
        End If
        pGxApp.Refresh(pGxObj.Parent.FullName)
    End Sub
