.dbf to XY Event to shapefile
994
06-09-2010 09:16 AM
RuchiraWelikala
Hi All,
I'm trying to run this code and seems to be getting an error.  I think the problem is with the "esriDataSourcesOleDB.OLEDBWorkspaceFactory".  Can someone confirm this?  What should I use to import the data as an XY Event?
Imports ESRI.ArcGIS.esriSystem
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.DataSourcesFile
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.Geometry
Imports System.IO
Imports ESRI.ArcGIS.Carto
Module mod_AddShapefile
    Public Sub AddShapeFile(ByVal MxDoc As IMxDocument, ByVal m_App As IApplication, _
                            ByVal TableName As String, ByVal FilePath As String)
        Try
            ' Part 1:  Define the workspace for the updated dbf stored locally.
            Dim pWorkspaceName As IWorkspaceName = New WorkspaceName
            Dim pTableName As ITableName = New TableName
            Dim pDatasetName As IDatasetName = pTableName
            ' Define the input tables's workspace
            pWorkspaceName.PathName = FilePath
            pWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesOleDB.OLEDBWorkspaceFactory"
            pDatasetName.Name = TableName & ".dbf"
            pDatasetName.WorkspaceName = pWorkspaceName
            ' Part 2:  Define the XY Events source Name object
            Dim pXYEvent2FieldsProperties As IXYEvent2FieldsProperties = New XYEvent2FieldsProperties
            Dim pSpatialReferenceFactory As ISpatialReferenceFactory = New SpatialReferenceEnvironment
            Dim pGCS As IGeographicCoordinateSystem
            Dim pXYEventSourceName As IXYEventSourceName = New XYEventSourceName
            ' Set the event to fields properties.
            With pXYEvent2FieldsProperties
                .XFieldName = "SUR_LONG83"
                .YFieldName = "SUR_LAT83"
                .ZFieldName = ""
            End With
            ' Set the spatial reference
            pGCS = pSpatialReferenceFactory.CreateGeographicCoordinateSystem(esriSRGeoCSType.esriSRGeoCS_NAD1983)
            ' Specify the event source and its properties
            With pXYEventSourceName
                .EventProperties = pXYEvent2FieldsProperties
                .SpatialReference = pGCS
                .EventTableName = pTableName
            End With
            ' Part 3:  Create a layer from the event source
            Dim pXYEventSource As IXYEventSource
            Dim pFLayer As IFeatureLayer = New FeatureLayer
            Dim pName As IName = pXYEventSourceName
            pXYEventSource = pName.Open
            pFLayer.FeatureClass = pXYEventSource
            pFLayer.Name = "Events"
            ' Set the output shapefile
            Dim pShapeName As IDatasetName = New FeatureClassName
            Dim pShapeWSFactory As IWorkspaceFactory = New ShapefileWorkspaceFactory
            Dim pShapeWS As IDataset = pShapeWSFactory.OpenFromFile(FilePath, m_App.hWnd)
            Dim pShapeWSName As IWorkspaceName = pShapeWS.FullName
            pShapeName.Name = TableName & "_shape"
            pShapeName.WorkspaceName = pShapeWSName
            Dim Fshp As New FileInfo(FilePath & "\" & TableName & "_shape.shp")
            Dim Fdbf As New FileInfo(FilePath & "\" & TableName & "_shape.dbf")
            Dim Fprj As New FileInfo(FilePath & "\" & TableName & "_shape.prj")
            Dim Fsbn As New FileInfo(FilePath & "\" & TableName & "_shape.sbn")
            Dim Fsbx As New FileInfo(FilePath & "\" & TableName & "_shape.sbx")
            Dim Fshx As New FileInfo(FilePath & "\" & TableName & "_shape.shx")
            If Fshp.Exists = True Then
                Fshp.Delete()
                Fdbf.Delete()
                Fprj.Delete()
                Fsbn.Delete()
                Fsbx.Delete()
                Fshx.Delete()
            End If
            ' Convert the data to shapefile
            Dim pFDConverter As IFeatureDataConverter = New FeatureDataConverter
            pFDConverter.ConvertFeatureClass(pName, Nothing, Nothing, pShapeName, Nothing, Nothing, "", 1000, m_App.hWnd)
            If MsgBox("Shapefile created.  Add to current map?", MsgBoxStyle.YesNo, "PetroGIS") = MsgBoxResult.Yes Then
                Dim pFeatureWorkspace As IFeatureWorkspace = pShapeWS
                Dim pNLayer As IFeatureLayer = New FeatureLayer
                pNLayer.FeatureClass = pFeatureWorkspace.OpenFeatureClass(pShapeName.Name)
                pNLayer.Name = pShapeName.Name & "_upt"
                ' Add the feature layer to the focus map
                MxDoc.AddLayer(pNLayer)
                MxDoc.ActiveView.Refresh()
            Else
                Exit Sub
            End If
        Catch Ex As Exception
            MsgBox(Ex.Message, MsgBoxStyle.Critical, "PetroGIS")
        End Try
    End Sub
End Module
RuchiraWelikala
Figured it out!
instead of using "esriDataSourcesOleDB.OLEDBWorkspaceFactory"
, you have to use "esriDataSourcesFile.ShapefileWorkspaceFactory".
