Cut Polygon
1135
11-24-2010 10:04 AM
shravanshravan
for the cut polygon snippet, i used "base tool" &  in the base tool, we have a class by name "class1" where  i pasted the snippet. could you please tell me in order to access this tool how the declaration has to be done and where it has to be done - whether onclick(), onmousedown();...
public override void OnClick()
            // TODO: Add cut1.OnClick implementation
        public override void OnMouseDown(int Button, int Shift, int X, int Y)
            // TODO:  Add cut1.OnMouseDown implementation
        public override void OnMouseMove(int Button, int Shift, int X, int Y)
            // TODO:  Add cut1.OnMouseMove implementation
        public override void OnMouseUp(int Button, int Shift, int X, int Y)
            // TODO:  Add cut1.OnMouseUp implementation
#region "Cut Polygon"
///<summary>Use a polyline to cut a polygon.</summary>
///<param name="polygon">An IPolygon interface that is the polygon to be split.</param>
///<param name="polyline">An IPolyline interface that is used to cut the input polygon.</param>
///<returns>An IGeometryCollection with polygons resulting from the split.</returns>
///<remarks></remarks>
public IGeometryCollection CutPolygon(IPolygon polygon, IPolyline polyline)
  if(polygon == null || polyline == null)
    return null;
  ITopologicalOperator4 topologicalOperator4 = polygon as ITopologicalOperator4; // Dynamic Cast
  IGeometryCollection geometryCollection = topologicalOperator4.Cut2(polyline);
  return geometryCollection;
#endregion
Venkata_RaoTammineni
hi,
You have to use onmousedown event for basetool.
Thanks and Regards,
Venkat Tammineni
