CreateRasterDataset in Geodatabase
1434
09-30-2013 01:52 PM
TerryGiles
using C#, visual studio 2010, ArcGIS 10.1 -
I'm using the following code to create a new RasterDataset in a file geodb -
                //create                 IRasterWorkspaceEx rWS = (IRasterWorkspaceEx)ws;                 IRasterStorageDef2 rStorage = new RasterStorageDefClass();                 rStorage.CellSize = new Pnt(){X=cellsize,Y=cellsize};                 rStorage.Origin = origin;                 IRasterDef2 rDef = new RasterDefClass();                 rDef.SpatialReference = srOut;                 rds = (IRasterDataset2)rWS.CreateRasterDataset(strName, 1, ptype, rStorage, "", rDef, null);
This works, but the output RasterDataset is only 1 pixel big.  When you call CreateRasterData through IRasterWorkspace (for file based rasters) you can specify the width and height.  Basically I have a 2d array I'm trying to write into the raster - how do I do this when the output is only 1 pixel big?
I've tried casting to IRasterProps and changing the Width and Height props but that throws a COMException even though in the help they look to be read/write props -
                IRasterBandCollection rbc = (IRasterBandCollection)rds;                 IRasterProps rProps = (IRasterProps)rbc.Item(0);                 rProps.NoDataValue = nodataval;                 rProps.Width = Data.GetLength(0);  //Error here                 rProps.Height = Data.GetLength(1);
A push in the right direction would be appreciated!
Thanks, Terry
NeilClemmons
Honored Contributor
Have you tried IRasterWorkspace2.CreateRasterDataset?  It has input params for the number of rows and columns.
NeilClemmons
Honored Contributor
TerryGiles
Thanks Neil,
the ArcObjects help is not very clear on that.  Actually it is clear, it says
IRasterWorspace2 is used to access a raster stored in a file system in any supported raster format. To access raster from geodtabase, use IRasterWorkspaceEx interface.
Reading that, I assumed it would create a tiff file (or whatever format I passed in as the Format parameter) in the folder of my file geodatabase, but testing with my existing code that uses IRasterWorkspace2 seems to work properly.
