CreateFeatureClass failure in VB.net
1307
01-13-2011 07:59 AM
DanielFrye
I'm using ArcGIS 9.3.1 and trying to get the code to create a new feature class in an existing personal geodabase to work but I am having no luck.  When running in debug mode from within vb.net it will fail with the standard "LoaderLock" error where it tells you to not run managed code inside a DllMain.  I'm sure this is a simple problem that I'm just not seeing, but I've been searching the forums for a couple of days not with no luck.  If anyone has insight after looking at the code below I would be very thankful.
Dan
        Dim pGeomDef As IGeometryDef = New GeometryDef
        Dim pGeomDefEdit As IGeometryDefEdit = CType(pGeomDef, IGeometryDefEdit)
        With pGeomDefEdit
            .GeometryType_2 = esriGeometryType.esriGeometryPolygon
            Dim pSpatRefFact As ISpatialReferenceFactory2 = New ESRI.ArcGIS.Geometry.SpatialReferenceEnvironment
            Dim pGeoCoordSys As IGeographicCoordinateSystem = pSpatRefFact.CreateGeographicCoordinateSystem(ESRI.ArcGIS.Geometry.esriSRGeoCSType.esriSRGeoCS_WGS1984)
            .SpatialReference_2 = pGeoCoordSys
        End With
        Dim pFields As IFields = New Fields
        Dim pFieldsEdit As IFieldsEdit
        Dim pField As IField
        Dim pfieldEdit As IFieldEdit
        pFieldsEdit = pFields
        pField = New Field
        pfieldEdit = pField
        With pfieldEdit
            .Name_2 = "ObjectID"
            .Type_2 = esriFieldType.esriFieldTypeOID
        End With
        pFieldsEdit.AddField(pField)
        pField = New Field
        pfieldEdit = pField
        With pfieldEdit
            .Name_2 = "SHAPE"
            .Type_2 = esriFieldType.esriFieldTypeGeometry
            .GeometryDef_2 = pGeomDef
        End With
        Dim pWorkSpaceFactory As IWorkspaceFactory = New ESRI.ArcGIS.DataSourcesGDB.AccessWorkspaceFactory
        Dim pFWS As IFeatureWorkspace = pWorkSpaceFactory.OpenFromFile("c:\Dan\Data\DataFitness-1AOI.mdb", 0)
        Dim pFeatClass As IFeatureClass
        Dim pUID As New ESRI.ArcGIS.esriSystem.UID
        pUID.Value = "esriGeoDatabase.Feature"
        'FAILING HERE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
        pFeatClass = pFWS.CreateFeatureClass("TestFC1", pFieldsEdit, pUID, Nothing, esriFeatureType.esriFTSimple, "SHAPE", "")
SteveFang
You code looks fine from a initial glance.  However, I noticed you have a space in your geodatabase.  Not sure if it's intentional.  You really don't need the second PFieldsEdit = PFields.  Other than that, I can't see anything wrong.
DanielFrye
That extra space in the workspace path is just a mistake from when I pasted the code here.
Interestingly, if I change these two lines to create a shapefile rather than a feature class in a geodatabase it works just fine without making any chages to the CreateFeatureClass line.
ORIGINAL CODE
Dim pFWS As IFeatureWorkspace = pWorkSpaceFactory.OpenFromFile("c:\Dan\Data\DataFi tness-1AOI.mdb", 0)
NEW CODE
Dim pWorkSpaceFactory As IWorkspaceFactory = New ESRI.ArcGIS.DataSourcesFile.ShapefileWorkspaceFactory
Dim pFWS As IFeatureWorkspace = pWorkSpaceFactory.OpenFromFile("c:\Dan\Data\", 0)
DanielFrye
I've figured out that the problem was due to the fact that I was not defining the XY domain of the spatial reference for the geometry field.  All is working now.
LukeBadgerow
How was your code failing?
my stack trace is coming back with something what looks like a schema lock issue, but I'm not setting the XY Domain currently either (partly because I don't necessarily know what it's going to be prior to creation)
Attempted to read or write protected memory. This is often an indication that other memory is corrupt. ESRI.ArcGIS.Geodatabase at ESRI.ArcGIS.Geodatabase.IFeatureDataset.CreateFeatureClass(String Name, IFields Fields, UID CLSID, UID EXTCLSID, esriFeatureType FeatureType, String ShapeFieldName, String ConfigKeyword) at WaterEditorExtension.Model.SurveyUtilities.StreamWriting(String pointtype, String outfile, String[] record, IWorkspace workspace) in C:\Documents and Settings\lbadgerow\My Documents\Visual Studio 2008\Projects\WaterEditorExtension\WaterEditorExtension\Model\SurveyUtilities.cs:line 206.
