CreateESRISpatialReferenceFromPRJ returns The input is not a workstation prj
3310
04-29-2013 01:37 AM
TomKeidar
Im getting the following error while trying to execute CreateESRISpatialReferenceFromPRJ(string prjString).
But when im using CreateESRISpatialReferenceFromPRJFile(string prjFile) with the same prj string in the file it works fine.
What does this exception means;
"the input is not a workstation prj"
Tom
bojko108
I'm facing the same problem. Have you managed to find a solution?
MelitaKennedy
Esri Notable Contributor
The first method is used to convert from an ArcInfo Workstation-style coordinate system. Those are used with coverages, grids, and tins and stored in a prj.adf file.
