Copy a feature.shpe to another FeatureClass - Not right one
953
07-19-2017 04:35 AM
ShaningYu
Honored Contributor
I have an ArcObjects project.  In this project, FeatureClass Source (termed as fc_Source here) is compared with FeatureClass Target (termed as fc_Target).  The general logic is described below:
1)  Loop through fc_Source, get a feature, termed featureS.
2)  Check if the featureS. exists (or overlaps with a feature in fc_Target.
3)  If the return is true on 2), set featureS as fc_Source.NextFeature.  If the return is false in 2), featureS will be inserted into fc_Target, and then set featureS as fc_Source.NextFeature till all of the features in fc_Sourceare looped through.
In 3)'s Inserting a feature into fc_Target, I got such problem: the feature inserted does carry the featureS values but NOT its right geometry.  The inserted one's geometry is actually the NextFeature of fc_Source.  The simplified related code is below.
What is wrong in my code?  I do wish someone can point out.  Thanks a LOT.
            // Loop though fc_Source
                featCursor = fc_Source.Search(qfQuery, true);
                IFeature featureS = featCursor.NextFeature();
                // Loop featureS though fc_Target.  If found featureT != null; else Not Fount, featureT = null;
                IFeature featureT = getFeature_GeometryCompare(featureS, fc_Target);
              while ( featureS != null)  {
                    if (featureT != null) {
                    } else  {
                       featureT = Assign_TargetFeature(featureS, fc_Target);
                       featureT.Store();
//  "Assign Geometry & Values"
        IFeature Assign_TargetFeature(IFeature f_Source, IFeatureClass fc_Target) {
            IFeature f_Target = fc_Target.CreateFeature();
            f_Target.Shape = f_Source.Shape;
            // Assign values
            return f_Target;
ShaningYu
Honored Contributor
I have solved this problem.  The trick is that the .Store() CANNOT be used.  The proper solution is using feature.Insert(true).  My code is below:
IFeature InsertFeature(IFeature f_Source, IFeatureClass fc_Target) {
            IFeature f =  Assign_TargetFeature(f_Source, fc_Target );   // Assign values only
            IFeatureBuffer pFeatureBuffer = (IFeatureBuffer )f;
            IFeatureCursor pFeatureCursor = fc_Target.Insert(true);
            pFeatureBuffer.Shape = f_Source.Shape;
            pFeatureCursor.InsertFeature(pFeatureBuffer);
            return (IFeature)pFeatureBuffer;
Thanks for your review.
