confusing query filter
5059
14
11-05-2010 07:14 AM
Cut_EliaRahmi
Dear all
I'm trying to learn th code below and compare with mine. I use vba,  but I get confusing in part of query. What is the code that appropriate for me to change "StateId"? Thanks a lot for everyone who help
Example:
Public Sub ZoomToState(StateId As String)
Dim pQueryFilter As IQueryFilter
Dim queryStr As String
queryStr = "Land_Unit='" & StateId & "'"
Set pActView = pMxDoc.activeView
Set pQueryFilter = New queryFilter
pQueryFilter.WhereClause = queryStr
Set pFCursor = pFClass.Search(pQueryFilter, True)
End Sub
My code for query:
If cboKabupaten.Visible = True Then
    pQueryFilter.WhereClause = "Land_Unit = '" & cboSatuanLahan.Text & "' And KABUPATEN = '" & cboKabupaten.Text & "'"
Else
    pQueryFilter.WhereClause = "Land_Unit = " & "'" & cboSatuanLahan.Text & "'"
End If
Cut_EliaRahmi
I followed an example from an arcobjects' book how to create selection layer, but I need to modify in part of query and zoom to feature, when I got stuck in query, I ask to this forum by the title confusing query filter. Now, the problem is solved. Thanks Richard, Thank you so much..
Regards,
Amie
RichardFairhurst
Regards,
Amie
I am glad it is working for you now.  Did you end up with just the first Sub or did you keep 2 Subs?  Did you end up keeping the line that stored the Definition Query whereclaues on the Soils layer or deleting it?  Did you leave the features selected or clear the selection at the end of the Sub?  Just curious to know what behaviors you ultimately were looking for.
Cut_EliaRahmi
I just use the first Sub, delete the Definition Query whereclause and clear the selection at the end of the Sub. Thanks Richard..
hamadaltuwaijri
I am having problem with my code I am trying to use zoom Modules in my project, BUT
after I run the code, it goes directly to the layer but with deleting all the information in Attribute table?
here is my code ?
Option Explicit
Private pMxDoc As IMxDocument
Private pFLayer As IFeatureLayer
Private pEnumLayer As IEnumLayer
Private pCurrentLayer As IFeatureLayer
Private pFClass As IFeatureClass
Private pFeature As IFeature
Public Sub ZoomToSDnumber(SDnumberId As String)
    Set pMxDoc = ThisDocument
    Set pFLayer = pMxDoc.FocusMap.Layer(0)
    Set pFClass = pFLayer.FeatureClass
    Dim pEnv As IEnvelope
    Dim pActView As IActiveView
    Dim pFCursor As IFeatureCursor
    Dim pQFilt As IQueryFilter
    queryStr = "SD_NUMBER = '" & SDnumberId & "'"
    Set pActView = pMxDoc.ActiveView
    Set pQFilt = New QueryFilter
    pQFilt.WhereClause = queryStr
    Set pFCursor = pFClass.Search(pQFilt, True)
    Set pFeature = pFCursor.NextFeature
        If pFeature Is Nothing Then
            MsgBox "Check spelling and case", vbCritical + vbExclamation, "State Not Found!"
        Else
            pActView.Extent = pFeature.Shape.Envelope
            Set pEnv = pActView.Extent
            pEnv.Expand 1.1, 1.1, True
            pActView.Extent = pEnv
        End If
    Dim flDef As IFeatureLayerDefinition
    Set flDef = pFLayer
    flDef.DefinitionExpression = "SDNUMBER='" & SDnumberId & "'"
    pActView.Refresh
    pMxDoc.UpdateContents
End Sub
Public Function CreateSelLayer(SDnumberId As String)
    ''** Make a selection on the FeatureLayer
    Dim qF As IQueryFilter
    Set qF = New QueryFilter
    queryStr = "SD_NUMBER='" & SDnumberId & "'"
    qF.WhereClause = queryStr
    Dim pFSel As IFeatureSelection
    Set pFSel = pFLayer
    pFSel.SelectFeatures qF, esriSelectionResultNew, False
    Dim pFDef As IFeatureLayerDefinition
    Set pFDef = pFLayer
    Dim SelFeatLayer As IFeatureLayer
    Set SelFeatLayer = pFDef.CreateSelectionLayer(StateId, True, "", "")
    With pMxDoc
        .AddLayer SelFeatLayer
        .FocusMap.MoveLayer SelFeatLayer, 2
        .FocusMap.ClearSelection
        .ActiveView.Refresh
        .UpdateContents
    End With
End Function
RichardFairhurst
I have corrected the definition query statement in bold where you misspelled the field name (you left out an underscore).  It should work with that correction.
here is my code ?
Option Explicit
        Else
        End If
    Set flDef = pFLayer
    flDef.DefinitionExpression = "SD_NUMBER='" & SDnumberId & "'"
    pActView.Refresh
End Sub
    Set pFSel = pFLayer
    Set pFDef = pFLayer
    With pMxDoc
        .ActiveView.Refresh
        .UpdateContents
    End With
End Function
