CommandBars.Find not working in 10.2.1.3497
2813
03-19-2014 06:16 AM
FrancescoGiovinazzo
Hello,
I have created a simple ArcMap AddIn, Framework .Net 3.5, with a single button in it.
The click method is this one:
protected override void OnClick() {     try     {         UID commandID = new UIDClass();         commandID.Value = "esriArcMapUI.ZoomToSelectedCommand";          ICommandItem comm = ArcMap.Application.Document.CommandBars.Find(commandID.Value);           if(comm != null)              comm.Execute();     }     catch     {     } }
The problem is,
comm
is always null, no matter wich button i search or if i use the guid instead, nothing is returned
Anyone with the same problem, and hopefully, a solution?
This code was working up to 10.1
Thanks
Fra
DuncanHornby
MVP Notable Contributor
In VB .net this code works, the main differences are highlighted in bold red:
Dim uid As New UIDClass
uid.Value = "esriArcMapUI.ZoomToSelectedCommand"
Dim pCommandItem As ICommandItem
pCommandItem = My.ArcMap.Application.Document.CommandBars.Find(uid, True)
If Not pCommandItem Is Nothing Then
      pCommandItem.Execute()
End If
Duncan
DuncanHornby
End If
Duncan
FrancescoGiovinazzo
Hello Duncan,
in C# there is no need for the My prefix, and the true you highlight is basicly an override of the default parameter "noRecurse = false"
However, i tried the same code with the , true and nothing changed, still null, thank you for trying that
Fra
AhmedEl-Sisi
Try "esriArcMapUI.MxSelectionMenu" instead of "esriArcMapUI.ZoomToSelectedCommand"
    try
        commandID.Value = "esriArcMapUI.MxSelectionMenu";
         if(comm != null)
             comm.Execute();
    catch
All 10.2 GUIDs (CLSID / ProgID):
http://resources.arcgis.com/en/help/arcobjects-net/conceptualHelp/#/ArcMap_commands/00010000029s0000...
Regards,
FrancescoGiovinazzo
Hello cc4ever,
I tried many of the ids in the link you gave me, but everyone is still returning null, without errors... i don't know where i could possibly look into
On a sidenote, if I add to watch the instruction "Predefined type 'Microsoft.CSharp.RuntimeBinder.Binder' is not defined or imported" and evaluate the expression, it says "Predefined type 'Microsoft.CSharp.RuntimeBinder.Binder' is not defined or imported"
A quick google shows me that it's a 4.0 issue, but my addin is 3.5... mysteries
Regards
Fra
FrancescoGiovinazzo
Found my problem, and i think i am stupid, giving credit to Duncan for the fix
I was passing commandID.Value to the Find method, instead of the commandID itself
Problem solved
This
ICommandItem comm = ArcMap.Application.Document.CommandBars.Find(commandID);
Is now working as expected
Thank you
Fra
