checking exsiting file geodatabase.
6285
05-28-2013 09:04 AM
NadeemQazi
I am using ARCObject SDK in  visual studio 2010  and C#. I want to check if a file geodatabase exist in a given folder. i have sued following code  to create a personal filegeodatabase or .gdb file .Here is my code:
IWorkspaceFactory workspaceFactory = new FileGDBWorkspaceFactoryClass();
            workspaceFactory.ContainsWorkspace(wrkspcpth, "MyMediaPlayer.gdb");
and now i want if this file exist it  not re created.   Any suggestion  how to check if the a given geofiledatabase already exist.
regards
nadeem
nicogis
IWorkspaceFactory2 wsf = new FileGDBWorkspaceFactoryClass() as IWorkspaceFactory2;
if (wsf.IsWorkspace(fileGdb))
   ws = wsf.OpenFromFile(fileGdb, 0);
Venkata_RaoTammineni
try this ...
public static IWorkspace CreateFileGdbWorkspace(String path)
   // Instantiate a file geodatabase workspace factory and create a file geodatabase.
   // The Create method returns a workspace name object.
  Type factoryType = Type.GetTypeFromProgID(
   "esriDataSourcesGDB.FileGDBWorkspaceFactory");
  IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)Activator.CreateInstance
  (factoryType);
  IWorkspaceName workspaceName = workspaceFactory.Create(path, "MyGDB.gdb", null,
  0);
   // Cast the workspace name object to the IName interface and open the workspace.
  IName name = (IName)workspaceName;
  IWorkspace workspace = (IWorkspace)name.Open();
   return workspace;
Thanks and Regards,
Venkat
