Dim dt As Object = "" Dim bExists As Boolean = gp.Exists(path, dt)
Dim pGPUtil As IGPUtilities Dim pDataElement As IDataElement pGPUtil = New GPUtilities ' Add a rasterdataset to the map pDataElement = New DERasterDataset pDataElement.CatalogPath = path pGPUtil.AddToMap(pDataElement, "", False, Nothing) ' Add a featureclass to the map pDataElement = New DEFeatureClass pDataElement.CatalogPath = path pGPUtil.AddToMap(pDataElement, "", False, Nothing)
