CHECK FOR NULL IN VB
28187
09-20-2010 11:23 AM
DonJohnson
I am trying to identify a NULL value in a string field and assign a value.
IsNull = True is causing an error.
Any other suggestions?
NeilClemmons
Honored Contributor
The following is VB.NET.
    Public Shared Function GetStringValue(ByVal value As Object) As String
        If value Is DBNull.Value Then
            Return String.Empty
        Else
            Return Convert.ToString(value)
        End If
    End Function
DonJohnson
I am using ModelBuilder and have the following:
Dim ROAD as String
ROAD = [ROAD_NAME]
if isNull(ROAD) = True then
ROAD = "NONE"
End If
JamesCrandall
Not familiar with ModelBuilder, but the VB.NET function to check for null values is the IsDBNull function.  Maybe something like this? (although I am not sure about getting/setting your "[ROAD_NAME]" value):
Dim ROAD As String
If Not IsDBNull([ROAD_NAME]) Then
  ROAD = [ROAD_NAME]
Else
  ROAD = "NONE"
End If
Dim ROAD as String
ROAD = [ROAD_NAME]
ROAD = "NONE"
End If
JohnHauck
Please use the following:
Dim ROAD as String
If IsNull( [ROAD_NAME]) Then
ROAD = "NONE"
Else
ROAD = [ROAD_NAME]
End If
EllenTejan
Thank you don
I imbeded
isNull(ROAD) = True
into  my expression and it worked for me.
Ellen
