cast from IFeatureClass to ISchemaLock  (ARCGIS)
798
04-23-2013 06:17 AM
EricPlante
Hi
I'm programming with the ARCGIS Java SDK, in Eclipse.
I need to cast an IFeatureClass to an ISchemalock. This cast is supposed to be allowed. There is an example of this cast in: http://resources.esri.com/help/9.3/arcgisengine/java/doc/b22267cb-642c-11dc-9ca3-0b35f906bb2e.htm
However, when I try to perform this cast in my code, an exception appears:
Exception in thread "main" java.lang.ClassCastException: com.esri.arcgis.geodatabase.IFeatureClassProxy cannot be cast to com.esri.arcgis.geodatabase.ISchemaLock
Are you able to make this cast on an IFeatureClass ? Here is the code to perform this:
//Attempt to acquire an exclusive schema lock on the feature class.
ISchemaLock schemaLock = (ISchemaLock)featureClass;
I would appreciate if you could try this simple line of code in one of your programs, and let me know if you get an exception.
Keep me posted...
MarkBaird
Hi again Eric,
Moving you post to the ArcObjects forum so you geta better reply.
However if you need any Runtime Java API info, we can help you loads 🙂
Mark
