cannot use "Application.FindExtensionByCLSID(pID)" "application" - not found
881
11-20-2011 12:36 AM
matthewandreatta
Hi all, migrating some VBA code to VB dotnet in an addin for arcmap 10.  Using visual studio 2010.
This line
pEditor = Application.FindExtensionByCLSID(pID)
give this error
Error 8 'FindExtensionByCLSID' is not a member of 'System.Windows.Forms.Application'.
Is there a reference missing? I have tried "My.ArcMap.Application.Document" but cannot get to the findextension.
Any suggestion.
RichardFairhurst
This line
give this error
Any suggestion.
Assuming this is being built as an Add-in for ArcMap you should be able to use:
pEditor = ArcMap.Application.FindExtensionByCLSID(pID)
or
pEditor = My.ArcMap.Application.FindExtensionByCLSID(pID)
I also assume you have created a reference to Editor and Imported it already, but since you don't show the code that sets up the pEditor variable or the pID variable, I can't tell.
