Cannot obtain reference to Application
1235
06-16-2011 09:59 AM
ESRICustomer
My Environment:
  • ArcObjects 9.3.1
  • VB.NET
  • Visual Studio 2008
I have built a user control (see attached pic) that uses the toolbar, table of contents control, and map control.
I am trying to access built in commands to use through code.
It's my understanding that to do this I need to be able to get to the CommandBars class by
Application.Document.CommandBars.Find(UID)
If a standalone application based on ArcEngine does not have Application, then how do people writing this type of application execute commands.
If this is relevant, when I open a map document (mxd), this is the meat of the code involved in that...
Private _esriIMapDoc As IMapDocument
Private _esriMapControl As ESRI.ArcGIS.Controls.AxMapControl
Public Sub OpenMxd(ByVal MxdFileNameAndPath As String)
    _esriIMapDoc = New MapDocument
    _esriIMapDoc.Open(MxdPathAndFileName, "")
    _esriMapControl.Map = _esriIMapDoc.Map(0)
End Sub
RichardWatson
I think Application comes with ArcMap, i.e. you have to be running the ArcGIS Desktop application to use this.  I get the sense that you are writing a stand-alone application based on ArcEngine.
ESRICustomer
You're correct, I am writing a standalone app based on ArcEngine.  I revised my original post to reflect this fact.
