Can't sign add-in with ESRISignAddIn.exe version 10.2.2.3552 (solved)
4336
03-17-2016 03:11 AM
FossiG_
Hello experts,
when trying to sign my ArcMap-Addin with the ESRISingAddIn.exe-Tool I receive the following message
Esri Digital Sign Add-In Utility
MS.Internal.IO.Packaging.CustomSignedXml.GetNetFxSecurityRegistryValue(System.String, Int64)
OK
followed by
Failed to sign the add-in.
OK
Do you have any idea what could be the source of this problem.
Everything went fine with version 10.1 before, after upgrading to version 10.2.2 this error occurred.
The machine had ArcMap 10.1 and ArcObjects SDK before, both where updated to version 10.2.2.
OS is Windows 7 SP1 x64.
Any hint will be appreciated.
Thanks in advanceFossi
TungNghiem
Hello
We hit this problem recently as well. After hours of investigating, we found out that it was a Windows Security Update that caused it:
Microsoft Security Bulletin MS16-035 - Important
If you un-install this update (find the update number corresponding to your Windows version), the signing tool should work again.
Regards
Tung
FossiG_
Oh dear, hadn't thought about windows updates at all.
Yes, after removing KB3135988, signing works fine again.
Thank you so much, you saved my day!
HarmBruinsma
The update:
doesn't give  only a problem with the signing of an add-in but also that the signature isn't valid.
After install this update, our add-in gives this error message:
This is an important problem for us because we can not ask our customers to ignore some windows updates.
I hope, someone has a better solution for this problem
Harm
