Can't run VBA macro from the extension.
3400
07-23-2014 01:53 AM
SanajyJadhav
My scenario is as below .
1. I am opening an MXD from a standalone exe file.This is fine, the MXD is getting opened successfully.
2. I have developed an ArcMap extension and it it's Startup event, I want to call the the VBA macro inside the MXD.
3. The problem is here, I get an error "Error running VBA code : Error in macro"
4. The macro works fine manually, I means I open the MXD and run the macro manually, it runs fine.
Code to tun the macro is as below:
   private bool RunMyMacro(IApplication pApplication)
            try
                IMxDocument pMxDoc = pApplication.Document as IMxDocument;
                IMapDocument pMapDoc = pMxDoc as IMapDocument;
                //check the name of the MXD. IF it is what we wantm run the macro
                if (String.IsNullOrEmpty(pMapDoc.DocumentFilename) == false)
                    if (pMapDoc.DocumentFilename.Contains("MyMXDName"))
                        //run the macro
                        IVbaApplication pVBAApps = pApplication as IVbaApplication;
                        pVBAApps.RunVBAMacro("Project", "ThisDocument", "Trace_Transformers_LV", null);
                        return false;
                return true;
            catch (Exception ex)
                string errMsg = ex.Message;
                string stkTrace = ex.StackTrace;
                return false;
//Code of StartUp event of an extension
public void Startup(ref object initializationData)
IApplication pApps = initializationData as IApplication;
RunMyMacro(pApps);
Earlier, the macro was getting called from the EXE it self and it works fine .However, after running fine for a week or so, it starts throwing an error. To work around this, I'm trying to call the macro from the extension, but it is also not working.Even a simple HelloWorld macro is not getting called from the extension.
I would really appreciate any help on this issue.
S.
seria
by Esri Contributor
The following link from Microsoft might be of some help:
How to dynamically add and run a VBA macro from Visual Basic
https://support.microsoft.com/en-us/kb/219905
Just as an FYI, ESRI no longer supports VBA. Support for VBA stopped at ArcGIS version 10.0. Please migrate your VBA customizations to ArcObjects .NET (VB.NET or C#). The link below shows how this can be done.
Migrating VBA customizations to ArcGIS 10.1
http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/#/Migrating_VBA_customizations_to_...
