Can't disconnect folder (IGxCatalog)
841
02-03-2012 01:20 AM
AndrewEgleton
This should be quite simple, but how can I remove folder connections from IGxCatalog?
I've tried:
ESRI.ArcGIS.Catalog.IGxCatalog catalog = new ESRI.ArcGIS.Catalog.GxCatalogClass(); catalog.Location = "M:\\"; catalog.DisconnectFolder("M:\\");
but the connection to M:\ remains after running the code.
AndrewEgleton
Found an answer: http://forums.arcgis.com/threads/35682-Create-Connection-Folder-in-ArcCatalog-through-ArcMap-VB.NET?...
dded 2 lines of code after removing folder connections:
catalog.DisconnectFolder("M:\\"); ESRI.ArcGIS.Catalog.IGxFile gxFile = (ESRI.ArcGIS.Catalog.IGxFile)catalog; gxFile.Save();
Folder connections now are removed permanently.
AndrewEgleton
