Callout text overlapping
4847
15
07-08-2011 07:17 AM
JonathanMeyer
Anyone I have any suggestions on how to add some conflict detection for text callouts? I have a custom tool that labels certain features a user has selected. The problem is when these features are close together the labels overlap and must be moved by the user. I am arbitrarily setting an offset for the callouts from the features when creating them so they will display away from the feature. However, I can???t find an easy way to determine if the callout will overlap another callout before placing it on the map.
JonathanMeyer
It seems like ITextBackground.QueryBoundary should work but I'm getting an empty geometry returned.  I appreciate all the help by the way.
JeffreyHamblin
I got the same thing (empty geometry) using:
IPolygon poly = new PolygonClass();
textSymLeftAlign.Background.QueryBoundary(ArcMap.Document.ActiveView.ScreenDisplay.get_CacheMemDC(0),
    ArcMap.Document.ActiveView.ScreenDisplay.DisplayTransformation as ITransformation,
    poly);
System.Diagnostics.Debug.WriteLine("Background: " + poly.Envelope.Width + ", " + poly.Envelope.Height);
Looking at the object model, there is another to try: IQueryGeometry.QueryEnvelope. Implemented by BalloonCallout.
I wish I could be more direct help, but I'm trying to figure this one out too. Hopefully we'll nail it in the end.
JeffreyHamblin
Well... I spent some time with IQueryGeometry.QueryEnvelope and keep getting "method or operation not implemented".
I would think there is a way to get the balloon callout's envelope directly, but if you can't get it to work -- or if someone else doesn't jump into this thread with the solution  -- I found a cludgy way to get it: First place the element without an anchor and get the bounds of the callout. Then add the anchor.
public void PerformTest()
    double fromX = 0;
    double fromY = 0;
    ITextElement textElement = new TextElementClass();
    IElement element = textElement as IElement;
    IElementProperties elementProperties = element as IElementProperties;
    textElement.Text = "Sample text to go in a callout to test getting the size. " +
            "\r\nThis adds some text on a second line." +
            "\r\nThis adds some text on a third line.";
    ESRI.ArcGIS.Geometry.Point point = new ESRI.ArcGIS.Geometry.Point();
    double offSetX = 0;
    double offSetY = 0;
    if (ArcMap.Document.ActivatedView is IPageLayout)
        // inches, page layout units
        offSetX = 0.5;
        offSetY = 1;
    else
        // feet. This worked for my test map's scale.
        offSetX = 800;
        offSetY = 1500;
    // Set the location of the callout balloon (lower-left corner of text)
    point.PutCoords(fromX + offSetX, fromY + offSetY);
    element.Geometry = point;
    // Create text symbology
    IFormattedTextSymbol formattedTextSymbol = new TextSymbol() as IFormattedTextSymbol;
    stdole.IFontDisp fontFrom = formattedTextSymbol.Font;
    fontFrom.Size = 8;
    formattedTextSymbol.Font = fontFrom;
    formattedTextSymbol.HorizontalAlignment = esriTextHorizontalAlignment.esriTHALeft;
    ICallout callOut = new BalloonCalloutClass();
    formattedTextSymbol.Background = (ITextBackground)callOut;
    textElement.Symbol = formattedTextSymbol;
    IGraphicsContainer graphicsContainer = ArcMap.Document.ActivatedView as IGraphicsContainer;
    // Add the callout element without a leader to an anchor point
    graphicsContainer.AddElement(element, 0);
    // Get the bounds of callout envelope for just the balloon
    IEnvelope elementEnvelope = new EnvelopeClass();
    element.QueryBounds(ArcMap.Document.ActiveView.ScreenDisplay, elementEnvelope);
    System.Diagnostics.Debug.WriteLine("Element (Before Anchor): " + elementEnvelope.Width + ", " + elementEnvelope.Height);
    System.Diagnostics.Debug.WriteLine("  SpatialReference: " + (textElement as IGraphicElement).SpatialReference.Name);
    System.Diagnostics.Debug.WriteLine("  UpperLeft:" + elementEnvelope.UpperLeft.X + ", " + elementEnvelope.UpperLeft.Y);
    System.Diagnostics.Debug.WriteLine("  LowerLeft:" + elementEnvelope.LowerLeft.X + ", " + elementEnvelope.LowerLeft.Y);
    System.Diagnostics.Debug.WriteLine("  UpperRight:" + elementEnvelope.UpperRight.X + ", " + elementEnvelope.UpperRight.Y);
    System.Diagnostics.Debug.WriteLine("  LowerRight:" + elementEnvelope.LowerRight.X + ", " + elementEnvelope.LowerRight.Y);
    // Set the leader anchor point
    ESRI.ArcGIS.Geometry.Point anchorPTFrom = new ESRI.ArcGIS.Geometry.Point();
    anchorPTFrom.PutCoords(fromX, fromY);
    callOut.AnchorPoint = anchorPTFrom;
    // Must re-assign this or leader to anchor is not created on map and querybounds
    // returns same value as before
    // Get the bounds of the entire callout envelope surrounding balloon and leader
    System.Diagnostics.Debug.WriteLine("Element (After Anchor): " + elementEnvelope.Width + ", " + elementEnvelope.Height);
JonathanMeyer
Thats the same thing I was seeing Friday.  I figured I wasn't calling it correctly and was going to look at it again today.
kyleknoche
Did anyone figure this thing out yet?
I have balloon callouts that I just cannot get the shape for.  I've tried everything and nothing works.
JonathanMeyer
I ended up giving up and using the Maplex extension for what I needed to do.  Everything I tried ended up returning an empty geometry or method not implemented. One would think this should be possible but it's sure not documented anywhere.
If anyone does figure it out I also would be interested to know for future use.
