Calculate geometry
1382
12-15-2010 06:13 AM
USFS_AGOLAdministrator
Hello all,
I have written code to intersect two polygon layers, and then calculate the acres of the resulting intersected layer.  To verify that my tool is giving accurate info, I've run the same process using ArcToolbox intersect, and then right click the resulting layer's field name, and choosing "Calculate Geometry" to get the acres of the intersected layer.  The results from ArcToolbox and the results from my custom tool do not match.  I'm getting values for the acres of the intersected layer like:
My Custom Tool:                ArcToolBox:
108400.148                       108423.527
17108.401                         17112.09
11624.977                         11627.484
85768.753                         85787.251
So the results of my tool are in the same ball park as what I'm getting back from Toolbox, but I'd like to be able to call the same code that toolbox does when it executes "Calculate Geometry".  Does anyone have sample code of how to calculate acres using Calculate Geometry?
Here is the code I am currently using:
'Get the first feature.
            pUpDFCursor = pFeatureclass.Update(Nothing, False)
            pFeature = pUpDFCursor.NextFeature
            'Loop through all features.
            Do Until pFeature Is Nothing
                'Step the progress bar.
                pStatusBar.StepProgressBar()
                pArea = pFeature.Shape
                dblArea = pArea.Area
                'Calculate Acres from Area.
                pFeature.Value(pFeature.Fields.FindField(strField)) = pArea.Area / 4046.85642
                'Update all features with newly calculated acres.
                pUpDFCursor.UpdateFeature(pFeature)
            Loop
Can I call calculate geometry directly through arcobject?  I'm using Visual Studio 2008, .Net.
Venkata_RaoTammineni
Hello all,
17108.401                         17112.09
11624.977                         11627.484
85768.753                         85787.251
            Loop
Public Sub t_IArea_polygon()
   Dim pID As New UID
   pID = "esriEditor.editor"
   Dim pEditor As IEditor
   Dim pApp As IApplication
   Set pApp = Application
   Set pEditor = pApp.FindExtensionByCLSID(pID)
   If pEditor.SelectionCount <>  1 Then
     MsgBox "select one polygon"
     Exit Sub
   End If
   Dim pEnumFeat As IEnumFeature
   Dim pFeature As IFeature
   Dim i As Long
   Set pEnumFeat = pEditor.EditSelection
   Dim pArea As IArea
   Dim pCenter As IPoint
   Dim pLabel As IPoint
   Set pCenter = New Point
   Set pLabel = New Point
   Set pFeature = pEnumFeat.Next
   While Not pFeature Is Nothing
     If pFeature.Shape.GeometryType = esriGeometryPolygon Then
       Set pArea = pFeature.Shape
       MsgBox "+++Polygon::IArea properties..." & vbCrLf _
       & "Area = " & pArea.Area & vbCrLf _
       & "Center.X = " & pArea.Centroid.X & vbCrLf _
       & "Center.Y = " & pArea.Centroid.Y & vbCrLf _
       & pArea.LabelPoint.X & vbCrLf _
       & "LabelPoint.Y = " & pArea.LabelPoint.Y
       pArea.QueryCentroid pCenter
       pArea.QueryLabelPoint pLabel
       MsgBox "+++Polygon::IArea Queries..." & vbCrLf _
       & "Center = " & pCenter.X & "," & pCenter.Y & vbCrLf _
       & "Label = " & pLabel.X & "," & pLabel.Y & vbCrLf
     End If
   Wend
End Sub
