C# CreateFeaturesFromTextFile
1349
08-05-2010 08:29 AM
JimHenry
I am new to the ESRI SDK and I am looking to automate my ArcView GUI based task.  I am not sure if I am even on the right track?
using System.Linq;
using System.Text;
using System.Windows.Forms;
using ESRI.ArcGIS.SampleTools;
using ESRI.ArcGIS.Geoprocessor;
using ESRI.ArcGIS.esriSystem;
namespace EsriTest
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            CreateFeaturesFromTextFile a = new CreateFeaturesFromTextFile();
            a.Input_Text_File = @"C:\in.txt";
//in combile stops here with error  80040111
            Geoprocessor g = new Geoprocessor ();
            g.AddToolbox(a.Alias);
//I knew the below was a problem but I am stuck
            //g.Execute(new IGPProcess(), new ITrackCancel());
in.txt
CreateFeaturesFromTextFile 'C:\dataIn.txt' . 'C:\dataOut.shp' 'C:\Program Files\ArcGIS\Coordinate Systems\Geographic Coordinate Systems\World\wgs 1984.prj'
dataIn.txt
polyline
0 0
0 -99.3176813565276 40.0798595384306 0.0 0.0
0 -96.3237815000927 38.0960181079531 0.0 0.0
1 0
0 -99.1184311878643 35.411993948899 0.0 0.0
2 0
0 -93.1532478820156 35.2528371349043 0.0 0.0
3 0
0 -93.0996253349636 40.0025957282976 0.0 0.0
END
JimHenry
Found this link for my first error:
http://blogs.esri.com/Dev/blogs/arcgisdesktop/archive/2009/12/01/Migrating-to-Engine-9.4-and-using-t...
Summary:
At 10, ESRI has introduced the new RuntimeManager Class.  This class can be used to interrogate which products are on the machine and then bind to a product.
reference ESRI.ArcGIS.Version
ESRI.ArcGIS.RuntimeManager.Bind(ESRI.ArcGIS.ProductCode.Engine);
JimHenry
For anyone the cares here is the working solution:
using System;
using System.Collections;
using System.Text;
namespace EsriTest
    class EsriTest
        static void Main(string[] args)
            Geoprocessor GP = new Geoprocessor();
            a.Output_Feature_Class = @"dataOut.shp";
            a.Output_Feature_Class_Spatial_Reference = @"C:\Program Files\ArcGIS\Coordinate Systems\Geographic Coordinate Systems\World\wgs 1984.prj";
            a.Input_Decimal_Separator = ".";
            RunTool(GP, a, null);
        private static void RunTool(Geoprocessor geoprocessor, IGPProcess process, ITrackCancel TC)
            // Set the overwrite output option to true
            geoprocessor.OverwriteOutput = true;
            // Execute the tool
            try
                geoprocessor.Execute(process, null);
                ReturnMessages(geoprocessor);
            catch (Exception err)
                Console.WriteLine(err.Message);
        // Function for returning the tool messages.
        private static void ReturnMessages(Geoprocessor gp)
            if (gp.MessageCount > 0)
                for (int Count = 0; Count <= gp.MessageCount - 1; Count++)
                    Console.WriteLine(gp.GetMessage(Count));
AkashJain
I cannot locate/add ESRI.ArcGIS.Version assembly.
I am using ArcGIS Desktop 10 with VS 2008 on Windows 7.
Please help.
LukeBadgerow
I'm just struggling to find the Execute Method that takes IGPProcess as an input.
I'm stuck with the one that takes a string input, and when I use that, my application just kind of fades away.  the code I'm working with currently:
    class ExportGeoprocessing
        GeoProcessor gp = new GeoProcessor();
        IGPUtilities gputils = new GPUtilitiesClass();
        public void ExecuteGeoprocessingTask(String infeature, String outfeature,
            IWorkspace outworkspace, IFeatureWorkspace inputworkspace, IFields fields, Hashtable fieldpairings)
            String extension = outfeature.Split('.')[1];
            IVariantArray parameters = null;
            object severity = 2;
            switch (extension)
                case("dbf"):
                    parameters = BuildParameterObjectForTable(infeature, outfeature, outworkspace, inputworkspace, fields, fieldpairings);
                    break;
                case("shp"):
                    parameters = BuildParameterObjectForShapefile(infeature, outfeature, outworkspace, inputworkspace, fields, fieldpairings);
                    try
                        gp.Execute("FeatureclassToFeatureclass_conversion", parameters, null);
                    catch
                        Console.WriteLine(gp.GetMessages(ref severity).ToString());
                    break;
        private IVariantArray BuildParameterObjectForShapefile(String infeature, String outfeature,
            IWorkspace outworkspace, IFeatureWorkspace inputworkspace,IFields fields, Hashtable fieldpairings)
            IVariantArray parameters = new VarArrayClass();
            IName fcname = GetFeatureName(infeature, outfeature, (IWorkspace)inputworkspace);
            IFeatureClass infc = inputworkspace.OpenFeatureClass(infeature);
            IGPFieldMapping fieldmapping = BuildOutputFieldMapping(fcname, fields, fieldpairings);
            parameters.Add(infc);
            parameters.Add(outworkspace); //make a string object
            parameters.Add(outfeature);
            parameters.Add(" ");
            parameters.Add(fieldmapping);
            return parameters;
        private IVariantArray BuildParameterObjectForTable(String infeature, String outfeature,
            ITable intable = inputworkspace.OpenTable(infeature);
            return parameters;
        private IName GetFeatureName(String infeature, String outfeature, IWorkspace workspace)
            IName infeaturename = null;
            String infcname = infeature.Split('.')[1];
            switch (extension)
                case ("dbf"):
                    IEnumDatasetName tablenames = workspace.get_DatasetNames(esriDatasetType.esriDTTable);
                    infeaturename = AssignNameVariable(infcname, tablenames);
                    break;
                case ("shp"):
                    IEnumDatasetName dsnames = workspace.get_DatasetNames(esriDatasetType.esriDTFeatureClass);
                    if (infeature.Contains("\\"))
                        IDatasetName ds = dsnames.Next();
                        while (ds != null)
                            IEnumDatasetName fcs = ds.SubsetNames;
                            infeaturename = AssignNameVariable(infcname, fcs);
                    else
                        infeaturename = AssignNameVariable(infcname, dsnames);
                    break;
            return infeaturename;
        private IName AssignNameVariable(String infeaturename, IEnumDatasetName dsnames)
            IName infcname = null;
            IDatasetName fc = dsnames.Next();
            while (fc != null)
                if (fc.Name.ToUpper().Contains(infeaturename.ToUpper()))
                    if (infcname == null)
                        infcname = (IName)fc;
                    break;
            return infcname;
        private IGPFieldMapping BuildOutputFieldMapping(IName fcname, IFields fields, Hashtable fieldpairings)
            IGPFieldMapping fieldmapping = new GPFieldMappingClass();
            IDETable intable = (IDETable)gputils.MakeDataElementFromNameObject(fcname);
            IArray intables = new ArrayClass();
            intables.Add(intable);
            fieldmapping.Initialize(intables, null);
            IFields infields = intable.Fields;
            foreach (String key in fieldpairings.Keys)
                int fieldindex = fieldmapping.FindFieldMap(fieldpairings[key].ToString());
                IGPFieldMap tempfieldmap = fieldmapping.GetFieldMap(fieldindex);
                int tempmapindex = tempfieldmap.FindInputField(intable, fieldpairings[key].ToString());
                IField inputfield = tempfieldmap.GetField(tempmapindex);
                int inindex = infields.FindField(fieldpairings[key].ToString());
                IField fieldin = infields.get_Field(inindex);
                IGPFieldMap fieldmap = new GPFieldMapClass();
                fieldmap.OutputField = fields.get_Field(fields.FindField(key.ToString()));
                fieldmap.AddInputField(intable, fieldin, 0, fieldin.Length);
                fieldmapping.AddFieldMap(fieldmap);
                fieldmap.RemoveAll();
            return fieldmapping;
