Binding stand alone application to ArcGIS for Server
1205
02-25-2013 01:05 PM
GhassanKarwchan
I am building a stand alone .NET applications using ArcObjects.
I want to run it on the server, where I have ArcGIS for Server.
I am trying to bind the license at runtime to the ArcGIS server runtime.
But the application giving an error message "Invalid ArcGIS Runtime Binding"
I am using this command
RuntimeManager.Bind(ProductCode.Server)
I don't want to install the engine there or have a license for the engine, because the application run at night when there is no activity , so I want to use the server license
Is that possible?
RichardWatson
If you are using 10.1 then the application you build/run must be 64 bit.
A trivial way of checking this is:
Console.WriteLine(Environment.Is64BitProcess);
If you running a version prior to 10.1 then the application you build/run must be 32 bit.
