Bind attribute field to drop down list
5013
13
05-20-2010 12:59 AM
NehayaArabeiat
How can I bind attribute field to drop down list in .net application.
Thanks alot
JamesCrandall
Thanks alot
You will have to be a bit more specific in what you would like to do, as well as the project type (a .NET application can be many different things).  Isn't a "DropDownList" is an ASP.NET control (not totally sure on that)?  Or are you referring to a ComboBox Control that is placed on a Windows Form or UserControl?
I'm not a immediately aware of any specific methods that allow you to bind fields from an attribute table to an ASP.NET DropDownList control, but I'm sure there is a solution to get it done.
NehayaArabeiat
Yes you are right I building ArcGIS windows application and it is a combobox not a dropdownlist.
Thanks for your reply
JamesCrandall
This seems to be a popular topic lately 🙂
Here is a recent thread (as of yesterday) where someone is populating a ComboBox Control with the unique values of a particular layer's attribute field:
http://forums.arcgis.com/threads/4766-DataStatistics-Interface-and-System.Collection.IEnumerator
While this is not necessarily a "DataBinding" solution, it should at least get you started.
Good luck!
NehayaArabeiat
Thanks james but can I use it to access data from file geodatabase not from map layers.
JamesCrandall
If the GDB FeatureClass is loaded in ArcMap's TOC, then just set pTable (from the code sample in the other thread) to this.  Otherwise, you will have to setup an IFeatureWorkspace and specify the GDB that contains the Tables/FeatureClasses.
http://edndoc.esri.com/arcobjects/9.2/ComponentHelp/esriGeoDatabase/IFeatureWorkspace.htm
NehayaArabeiat
I have setup FileGDBWorkspaceFactory and define where the geodatabase file path but I how can I get the feature layer from it ??
JamesCrandall
I'm away from my dev workstation at the moment, but I think it's something like this:
Dim pTable As ITable
pTable = pFeatureWorkspace.OpenTable("Feature Class Name Goes here")
Or if it's a Layer I think you want something like this:
Dim pFeatureLayer As IFeatureClass
pFeatureLayer =  pFeatureWorkspace.OpenFeatureClass("Feature Class Name Here")
NehayaArabeiat
Hi James,
I'm trying to use the function in the previous thread but it displays this error:
Unable to cast COM object of type 'System.__ComObject' to interface type 'ESRI.ArcGIS.Carto.IFeatureLayer'
because the function needs featurelayer parameter and I have accessed to it featureclass, I cannot find a method to convert the featureclass to featurelayer
Here is the function code and button code:
Public Sub Sort_Unique(ByVal pLayer As IFeatureLayer, ByVal fieldname As String, ByVal condition As IQueryFilter)
        Dim pTableSort As ITableSort
        Dim sFieldName As String = fieldname
        Dim pCursor As ICursor
        Dim pFeatureLayer As IFeatureLayer
        pFeatureLayer = New FeatureLayer
        ' Gets the attribute table from the passed layer
        pTable = pLayer.FeatureClass
        ' This example sorts the specificed field name
        pTableSort = New TableSort
        With pTableSort
            .Fields = sFieldName
            .Ascending(sFieldName) = True
            .Table = pTable
        End With
        ' sort the table
        pTableSort.Sort(Nothing)
        ' Loop through sorted records and add to a listbox
        pCursor = pTableSort.Rows
        Dim pData As IDataStatistics
        pData = New DataStatistics
        pData.Field = fieldname
        pCursor = pLayer.Search(condition, False)
        pData.Cursor = pCursor
        Dim pEnumVar As System.Collections.IEnumerator
        Dim value As Object
        pEnumVar = pData.UniqueValues
        value = pEnumVar.MoveNext
        For i = 0 To pData.UniqueValueCount - 1
            Dist_List.Items.Add(CStr(pEnumVar.Current)) '<--- this should add the values to your cmbLot Control
    End Sub
    Private Sub Fill_Dist_List_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Fill_Dist_List.Click
        Dim pGDBWSF As IWorkspaceFactory
        pGDBWSF = New FileGDBWorkspaceFactory
        Dim pWorkSpace As IWorkspace
        pWorkSpace = pGDBWSF.OpenFromFile("E:\ArcGis Engine Projects\Data Layers\SDE GDB\sde_gdb.gdb", 0)
        Dim pEnumDataset As IEnumDataset
        pEnumDataset = pWorkSpace.Datasets(esriDatasetType.esriDTFeatureDataset)
        Dim pDataset As IDataset
        pDataset = pEnumDataset.Next
        Dim FCN As String
        FCN = Gov_List.SelectedText
        Dim pFeatureworkspace As IFeatureWorkspace
        pFeatureworkspace = pGDBWSF.OpenFromFile("E:\ArcGis Engine Projects\Data Layers\SDE GDB\sde_gdb.gdb", 0)
        Dim pFeatureclass As IFeatureClass
        pFeatureclass = pFeatureworkspace.OpenFeatureClass("amman_dist")
        Dim pFeaturelayer As IFeatureLayer
        'pFeaturelayer = pFeatureclass
        Dim Fieldname As String
        Fieldname = "DIST_NA"
        Dim pQFilter As IQueryFilter
        pQFilter = New QueryFilter
        pQFilter.WhereClause = "DIST_NA = 'ا�?جا�?عة' OR DIST_NA = 'ا�?ج�?زة' OR DIST_NA = 'ا�?ج�?ز�?' OR DIST_NA 'ا�?�?�?�?س�?�?'"
        Sort_Unique(pFeatureclass, Fieldname, pQFilter)
    End Sub
Thanks alot
JamesCrandall
Untested and I cannot remember exactly, but I think you need something like this:
Set pFeatureLayer = New FeatureLayer
Set pFeatureLayer.FeatureClass = pFeatureClass
So in the click event that sends the pFeatureLayer to your Sort_Unique Sub, you can try to set your pFeatureLayer as below.  (You'll have to test this as I am away from my dev workstation and just going off of a guess):
        Dim FCN As String
        Dim pFeaturelayer As IFeatureLayer = New FeautureLayer
        pFeaturelayer.FeatureClass = pFeatureclass
    End Sub
Thanks alot
