Bind attribute field to drop down list
5063
13
05-20-2010 12:59 AM
NehayaArabeiat
How can I bind attribute field to drop down list in .net application.
Thanks alot
NehayaArabeiat
Hi James,
Thanks for your reply the code works but I have another problem I want towant to concatenate a string with a featureclass name I try  gov = String.Concat(govlist, "_dist") but it displays
"not found table name"
JamesCrandall
Hi James,
You will have to provide the exact code you are trying to implement.  I cannot tell what it is you are attempting from the code snippet you provided.
Do you need to get the String value of the FeatureClass's name?
NehayaArabeiat
Here is the full code for the function and form load, I want to get the featureclass name and concatenate it with a string:
Public Sub FillDistricts(ByVal pclass As String, ByVal fieldname As String, ByVal pQF As String)
        pWorkSpace = pGDBWSF.OpenFromFile("E:\ArcGis Engine Projects\Data Layers\SDE GDB\sde_gdb.gdb", 0)
        '  pEnumDataset = pWorkSpace.get_datasets(ESRI.ArcGIS.Geodatabase.esriDatasetType.esriDTFeatureDataset)
        pEnumDataset = pWorkSpace.Datasets(esriDatasetType.esriDTFeatureDataset)
        ' pEnumDataset = pWorkSpace.Datasets(esriDatasetType.esriDTFeatureDataset)
        'pEnumDataset.Reset()
        pDataset = pEnumDataset.Next
        Dim FCN As String
        FCN = Gov_List.SelectedText
        pFeatureworkspace = pGDBWSF.OpenFromFile("E:\ArcGis Engine Projects\Data Layers\SDE GDB\sde_gdb.gdb", 0)
        Dim pTable As ITable
        Dim pTableSort As ITableSort
        Dim sFieldName As String = fieldname
        Dim pCursor As ICursor
        Dim pFeatureclass As IFeatureClass
        pFeatureclass = pFeatureworkspace.OpenFeatureClass(pclass)
        ' Gets the attribute table from the passed layer
        pTable = pFeatureclass
        ' This example sorts the specificed field name
        pTableSort = New TableSort
        With pTableSort
            .Fields = sFieldName
            .Ascending(sFieldName) = True
            .Table = pTable
        End With
        ' sort the table
        pTableSort.Sort(Nothing)
        ' Loop through sorted records and add to a listbox
        pCursor = pTableSort.Rows
        Dim pQFilter As IQueryFilter
        pQFilter = New QueryFilter
        pQFilter.WhereClause = pQF
        Dim pData As IDataStatistics
        pData = New DataStatistics
        pData.Field = fieldname
        pCursor = pFeatureclass.Search(pQFilter, False)
        'pCursor = pLayer
        pData.Cursor = pCursor
        Dim pEnumVar As System.Collections.IEnumerator
        Dim value As Object
        pEnumVar = pData.UniqueValues
        value = pEnumVar.MoveNext
        For i = 0 To pData.UniqueValueCount - 1
            Dist_List.Items.Add(CStr(pEnumVar.Current)) '<--- this should add the values to your cmbLot Control
    End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim govlist As String
        govlist = Gov_List.SelectedText
        Dim gov As String = ""
        'gov = govlist & "_dist"
        FillDistricts(gov, "DIST_NA", "Dist_NE <>' '")
    End Sub
JamesCrandall
Use .AliasName of the FeatureClass to access the name.  So in the portion of your code you supplied, just setup a string variable and set it to the .aliasname, which you can then use to concatenate.
Dim pFClassName As String
pFClassName = pFeatureClass.AliasName
Now you can use pFClassName in your concatenation:
Dim SomeOtherVariableStringValue As String
Dim ConcatenatedStr As String = pFClassName & "_" & SomeOtherVariableStringValue
