Basics of arc objects
2654
10
11-19-2010 08:54 PM
MuraliPandey
How do i create a Fillegeodatabase + import features(say point,line,polygon) from that using C#
If somebody have sample(simple) code then it will b best...
Thanks
RuchiraWelikala
Thanks
http://edndoc.esri.com/arcobjects/9.2/NET/fde31db0-af15-409f-81b5-75c23d4a762e.htm#CreateFGDB
MuraliPandey
Thanks for ur kind response.
Actually , I m a beginnar of arc objects (as reflected by my questions).
In addition to the above ,I m looking for sample exe application(Hello World Type in c#).
Venkata_RaoTammineni
hi,
  Please find the complete code... what you looking
private static void ExportShapefiles(string strFolderPath)
           try
               IWorkspaceName pWorkspaceName;
               IFeatureClassName pFeatClassName;
               IDatasetName pDataSetName;
               //define the wrokpace
               pWorkspaceName = new WorkspaceNameClass();
               pWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesGDB.AccessWorkspaceFactory";
               CreateAccessWorkspace(@"C:\temp\");
               pWorkspaceName.PathName = strFolderPath;
               //Define the dataset.
               pFeatClassName = new FeatureClassNameClass();
               pDataSetName = pFeatClassName as IDatasetName;
               pDataSetName.WorkspaceName = pWorkspaceName;
               pDataSetName.Name = "Export_Data";
               IWorkspaceName pInShpWorkspaceName;
               IFeatureClassName pFCName;
               IDatasetName pShpDatasetName;
               //Define the workspace.
               pInShpWorkspaceName = new WorkspaceNameClass();
               pInShpWorkspaceName.PathName = @"D:\Temp\Pro\Sample\Sample";
               pInShpWorkspaceName.WorkspaceFactoryProgID = "esriDataSourcesFile.ShapefileWorkspaceFactory";
               pFCName = new FeatureClassNameClass();
               pShpDatasetName = pFCName as IDatasetName;
               pShpDatasetName.Name = "polygon.shp";
               pShpDatasetName.WorkspaceName = pInShpWorkspaceName;
               IFeatureDataConverter pShpToFC;
               pShpToFC = new FeatureDataConverterClass();
               pShpToFC.ConvertFeatureClass(pFCName, null, null, pFeatClassName, null, null, "", 1000, 0);
               MessageBox.Show ("Shapefile conversion complete!");
           catch (Exception exp) { }
       public static void CreateAccessWorkspace(String path)
           try
               // Instantiate an Access workspace factory and create a personal geodatabase.
               // The Create method returns a workspace name object.
               Type factoryType = Type.GetTypeFromProgID(
                 "esriDataSourcesGDB.AccessWorkspaceFactory");
               IWorkspaceFactory workspaceFactory = (IWorkspaceFactory)
                 Activator.CreateInstance(factoryType);
               IWorkspaceName workspaceName = workspaceFactory.Create(path, "Sample.mdb",
                 null, 0);
               // Cast the workspace name object to the IName interface and open the workspace.
               IName name = (IName)workspaceName;
               IWorkspace workspace = (IWorkspace)name.Open();
               MessageBox.Show("Geo Database Just Created", "Data Creator");
Thanks and Regards,
Venkat Tammineni
MuraliPandey
Thanks Venkat.....!!
It will help me a lot....!!
Your welcome.......
MuraliPandey
Hi
please tell me  ,how should I proceed on learning arc objects (C#)...!!
Hi
Do you have C# knowledge ?
MuraliPandey
I m working in C++ ..
and little bit experience in C#.....
I want to start Arc ob..   in C# .....
You need to learn first .NET...then you can easily work with arcobjects .net...
Thanks and Regards,
Venkat
