ArcScene: Extrude polylineZM by M value
677
03-25-2011 03:11 AM
TychoSchol
In ArcScene 9.3.1 you can use the Z values in the features of a layer for their base height, but the extrusion can only be based on values in numeric fields.
Now I have a PolylineZM layer with noise barriers, in which the Z value contains the absolute height of the base of the barrier and the M value contains the height of the top.
Using the layer properties in ArcScene, I can't extrude each vertex using the M value, I can only calculate an average height, put this in a field and use this field to extrude the entire feature.
Is there a way, using ArcObjects, to set the extrusion for each vertex, using their own M values?
Any suggestion would be appreciated.
Tycho
