ArcScene Background Color - Harder than it should be.
1244
02-10-2011 01:10 PM
WilliamMcInnes
I'm having trouble setting the background color in ArcScene
I can "set" the backroundcolor i.e. the message box reports it as being changed, but it doesn't change in the scene.
The refreshviewers method refreshes the background to white, even though the default background is something different (150,0,150)
In the GUI, this code does set the combobox background color to grey (128,128,128)
but it doesn't apply.
Code attached below.
How do I get the background to change?
Public Sub ChangeBackground()
    Dim pSxDoc As ISxDocument
    Set pSxDoc = ThisDocument
    Dim pViews3d As IViewers3D
    Set pViews3d = pSxDoc.Scene.SceneGraph
    Dim r As Single
    Dim g As Single
    Dim b As Single
    pViews3d.SetBackgroundColor 128, 128, 128
    pViews3d.GetBackgroundColor r, g, b
    MsgBox r & g & b
    pViews3d.RefreshViewers
End Sub
End Sub
Cheers,
Will
Venkata_RaoTammineni
    Dim r As Single
    Dim g As Single
    Dim b As Single
    MsgBox r & g & b
End Sub
End Sub
Cheers,
Will
Mostly you play with Scene ..if you want to change and once you run the code...  go scene properties and press Restore Default colors
Public Sub test()
    Dim r As Single
    Dim g As Single
    Dim b As Single
    pViews3d.Scene.SetDefaultBackgroundColor 128, 128, 128
    pViews3d.GetAllViewers
End Sub
WilliamMcInnes
I added pViews3d.GetAllViewers, and it reports changing the color, but it still refreshes to white.
Thanks though.
