ArcObjects .NET 10.4
1906
08-25-2016 02:21 PM
EduardoSilveira1
Hi, I have some questions about ArcObjects for ArcGIS 10.4.
I've got a custom toolbar to ArcMap. This toolbar has developed for ArcMap 10.0. Although, I need to upgrade this toolbar to ArcMap 10.4.  I've done few steps. See below.
--- Update Library References ( Changed From ArcObjects 10.0 to ArcObjects 10.4)
--- Recompile the solution.
--- Change the .NET Framework Version (From 3.5 to 4.5).
--- Create an installer (.msi) for the toolbar
PS : This toolbar opens the ArcMap.
After I had done those steps, When I executed the installer.  The ArcMap opened strangely as if it hadn't loaded completely.
(See the picture).
Also, See Below my a part of source code.
public class FuncoesArcGIS
        #region Variáveis
        private string StrPatchFile = System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().CodeBase);
        public enum tpPapel
            A0 = 0,
            A1,
            A2,
            A3,
            A4,
        public enum StateSelect
            SelectAll = 0,
            DeselectAll,
        public enum OrientacaoPapel
            Retrato = 0,
            Paisagem,
        public enum TipoOttobacia
            Montante = 0,
            Jusante,
        private IApplication pIApplication;
        public IApplication PIApplication
            get { return pIApplication; }
            set { pIApplication = value; }
        /// <summary>
        /// Work Space Factory
        /// </summary>
        private IWorkspaceFactory pIWorkspaceFactory;
        public IWorkspaceFactory PIWorkspaceFactory
            get { return pIWorkspaceFactory; }
            set { pIWorkspaceFactory = value; }
        private IPoint pPoint;
        public IPoint PPoint
            get { return pPoint; }
            set { pPoint = value; }
        private IPointCollection pGonColl;
        public IPointCollection PGonColl
            get { return pGonColl; }
            set { pGonColl = value; }
        private IFeatureLayer pIFeatureLayer;
        public IFieldChecker fieldChecker;
        private IFeatureWorkspace pFeatureWorkspace;
        public MxDocument pMxDocument;
        #endregion
        #region Construtor
        public FuncoesArcGIS()
            this.pIWorkspaceFactory = new ShapefileWorkspaceFactoryClass();
            this.pPoint = new Point();
            this.pGonColl = new Ring(); //new MultipointClass();
            this.pIFeatureLayer = new FeatureLayer();
            this.fieldChecker = new FieldCheckerClass();
            this.pFeatureWorkspace = SetaWorkspace();
        public void Destructor()
            Marshal.FinalReleaseComObject(this.pIWorkspaceFactory);
            Marshal.FinalReleaseComObject(this.pPoint);
            Marshal.FinalReleaseComObject(this.pGonColl);
            Marshal.FinalReleaseComObject(this.fieldChecker);
            Marshal.FinalReleaseComObject(this.pFeatureWorkspace);
            Marshal.ReleaseComObject(this.pIWorkspaceFactory);
            Marshal.ReleaseComObject(this.pPoint);
            Marshal.ReleaseComObject(this.pGonColl);
            Marshal.ReleaseComObject(this.fieldChecker);
            Marshal.ReleaseComObject(this.pFeatureWorkspace);
            this.pIWorkspaceFactory = null;
            this.pPoint = null;
            this.pGonColl = null;
            this.pIFeatureLayer = null;
            this.fieldChecker = null;
            this.pFeatureWorkspace = null;
            GC.Collect();
            GC.WaitForPendingFinalizers();
        #endregion
        #region Metodos
        #region LoginSplash
        //1
        public void StartArcMap(bool blVisible)
            ESRI.ArcGIS.ArcMap.Application objApp;
            pMxDocument  = new ESRI.ArcGIS.ArcMapUI.MxDocument(); //.MxDocument//(IMxDocument)pIApplication.Document;
            try
                if (pMxDocument != null)
                    // Get a reference to the application
                    //objApp = pIMxDocument.Parent;
                    objApp = (Application)pMxDocument.Parent;
                    // Show ArcMap
                    objApp.Visible = blVisible;
                    MontarBarras(objApp);
            catch (Exception exL)
                throw new Exception(exL.Message);
        //2
        private void MontarBarras(ESRI.ArcGIS.ArcMap.Application objApp)
            try
               string strBarra = null;
               DataSet recBarra = new DataSet();
              ICommandBars commandBars = pMxDocument.CommandBars;
              ICommandBar menuBar = commandBars.Create("GeoDIMSYS - " + Assembly.GetExecutingAssembly().GetName().Version.Major + "." + Assembly.GetExecutingAssembly().GetName().Version.Minor, ESRI.ArcGIS.SystemUI.esriCmdBarType.esriCmdBarTypeToolbar);
              UID cmdId = new UIDClass();
              object objIndex = new object();
              recBarra.ReadXml(StrPatchFile + @"\Barras.xml");
              for (int i = 0; i < recBarra.Tables["row"].Rows.Count; i++)
                  if (recBarra.Tables["row"].Rows[i]["Dll"].ToString() == "GDSBAR")
                     strBarra = recBarra.Tables["row"].Rows[i]["Dll"].ToString() + "." + recBarra.Tables["row"].Rows[i]["Class"].ToString();
                     //cmdId.SubType = 5;
                     cmdId.Value = strBarra;
                     objIndex = menuBar.Count;
                     menuBar.Add(cmdId, ref objIndex);
            catch(Exception exl1)
                throw new Exception(exl1.Message);
        #endregion
        #endregion
Well, The main question is : Is there any difference to create commandbar from ArcObjects 10.0 to ArcObjects 10.4 ??
Best Regards,
