Arcobjects change table data source
8039
03-13-2015 04:42 AM
JonMorris2
I'm writing a C# addin to change all the data sources in an MXD from one SDE datasource to another. I can iterate through the layers and change feature layers and raster layers, but what about tables?
There is very little doc on this - it can be done in arcpy, but I could only find one old unanswered question for how to do it in arcobjects.
I've used the TableCollection to iterate through the tables in the map, but it's not clear how to update the source for each one. Any ideas?
JonMorris2
Anyone? Never mind, I've figured it out:
  // focus map
  IMap map = ...
  // new data source for table
  IFeatureWorkspace workspace = ...
  ITableCollection tableCollection = (ITableCollection)map;
  List<ITable> tables = new List<ITable>();
  for (int i = 0; i < tableCount; i++)
  tables.Add(tableCollection.get_Table(i));
  // iterate over a copy of the tables so we can add and remove
  foreach (ITable oldTable in tables)
  IDataset dataset = (IDataset)oldTable;
  IDatasetName datasetName = (IDatasetName)dataset.FullName;
  // assumes table name is same in new data source
  // get the new table
  ITable newTable = workspace.OpenTable(datasetName);
  // replace the table in the TOC
  tableCollection.RemoveTable(oldTable);
  tableCollection.AddTable(newTable);
  // fire change event to change table
  IMapAdmin2 mapAdmin2 = (IMapAdmin2)map;
  mapAdmin2.FireChangeTable(oldTable, newTable);
  // Redraw the map
  IActiveView activeView = (IActiveView)map;
  activeView.Refresh();
  // Refresh TOC
  ESRI.ArcGIS.ArcMapUI.IContentsView contentsView = ArcMap.Document.CurrentContentsView;
  contentsView.Refresh(null);
JonMorris2
  // focus map
  IMap map = ...
  // Redraw the map
  // Refresh TOC
BBulla
Hi Jon,
Thanks for posting this.  Could you also post the code you used for changing the datasource for featurelayers and raster??
JonMorris2
There's a snippet here that can change feature layer data source. The key thing is to call FireChangeFeatureClass after you've made the change to make sure the map is updated.
// Change FeatureClass of layer
  featureLayer.FeatureClass = newFeatureClass;
  mapAdmin2.FireChangeFeatureClass(oldFeatureClass, newFeatureClass);
