ArcObjects 10.2 - Map Control works with 1 form but not the next - licensing
3886
07-22-2014 05:24 AM
MichaelRutkowski
When initializing an application (going through the proper procedure of binding to the application then checking out a license), my main form which contains a mapcontrol, TOC control and a toolbar control loads up fine with no complications. My application contains a button which then loads up another form which also contains a map, and toc control. However, when the second form loads, I get a licensing error.
Exception Information: An error occurred creating the form. See Exception.InnerException for details.  The error is: You must have a license to use this ActiveX control.
Stack Trace:    at AART.My.MyProject.MyForms.Create__Instance__(T Instance)
   at AART.My.MyProject.MyForms.get_frmSuitabilityCreate()
   at AART.frmModifyAttributes.cmdNext1_Click(Object sender, EventArgs e)
Source: AART
Inner Exception: You must have a license to use this ActiveX control.
Inner Exception Stack Trace:    at System.Windows.Forms.AxHost.CreateInstance()
   at System.Windows.Forms.AxHost.GetOcxCreate()
   at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
   at System.Windows.Forms.AxHost.CreateHandle()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.AxHost.EndInit()
   at AART.frmSuitabilityCreate.InitializeComponent()
   at AART.frmSuitabilityCreate..ctor()
Inner Exception Source: System.Windows.Forms
This only occurs in production where the user has only an ArcGIS Desktop license (after publishing the application). In development where I'm running against an arcengine developers license the application works fine. The second form only contains a mapcontrol and toc... no other controls.
Is there a proper approach to initializing a second map control on a separate form?
On a windows 7 64bit machine running ArcGIS Desktop 10.2 in production. On development, a windows 7 64 bit machine running ArcEngine, Dev kit
